 grease points?
zoochy
Home City : Tropical Canada
Model and year : LH107G 1991
PostSubject: grease points?   Fri Jun 15, 2007 4:49 am
Does anyone have a diagram for the location of the grease nipples for the 4x4 Hiace?
Or even... How many I should be looking for?
Thanks.
PostSubject: Re: grease points?   Fri Jun 15, 2007 9:53 am
i can only suggest that the running gear will be similar to th hilux you could try looking on this site to see if it helps i have pasted it elsewhere in the forum cos info on these things is scarce.good luck http://www.toyotasurf.asn.au/techsite/index.htm
zoochy
PostSubject: Re: grease points?   Wed Jun 20, 2007 5:48 am
not much applicable on that site...
Anybody ever lube thier van? Give me the number of nipples and I'll keep looking to find them...
Number of posts : 150
Home City : Lincoln England
PostSubject: Re: grease points?   Wed Jul 18, 2007 8:29 pm
Here's a tip - There are blanking bolts on the top of the front wishbones, remove them and replace with grease nipples - M6 thread I think. Grease them before your MOT - the wish bones cost a fortune so regular lubrication should save money in the long run.
zoochy
PostSubject: Re: grease points?   Wed Sep 19, 2007 7:37 am
OK, so far I have found 5 grease nipples.
1+1 just in and in front of the front tire.
1+1 behind the front tire (had to take them off to get the grease gun on it.
And one on the front butterfly on the middle axel before the rear differential (muffler in background).
PostSubject: Re: grease points?   Wed Sep 19, 2007 10:26 am
Yours, in the pictures, obviously have the nipples on,mine didn't.
The wishbones from Toyota cost a fortune - on the internet can be 1/3 of the price - make sure you get the right part number if you need to replace them.
Number of posts : 1117
PostSubject: Re: grease points?   Wed Sep 19, 2007 11:32 pm
Thanks for posting pics.. I am sure that sort of info will help loads.
zoochy
PostSubject: Re: grease points?   Thu Sep 20, 2007 1:54 am
on the top (second image) but not on the bottom. The boot seems empty but I'm not sure how to get grease in there...?
Anybody else know of other grease points? In a couple weeks the "monsoon" will hit and the nice weather will be gone. I don't have a shop so I'd like to get this done soon.
Cheers.
grease points?
» The points system
» Activity Points
» Should the UK leave the EU.....YES or NO
» Cons of Censorship
» Hemlock Grove
