 Air con belt
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Air con belt   Wed Nov 04, 2009 4:45 pm
Afternoon all...
I need to replace the V belt that drives my air con compressor, its squeeling like a P I G, so looks to be a little S t r e t c h e d...
Managed to get the toyota part number from toyodiy.com.... but before i go and order one from them ( and no doubt get rodgered) has anyone picked up a pettern belt and if so any reference numbers or sites that can help ( UK particularly if poss)
Ta
Andy
phrollins
Number of posts : 89
Home City : Darwin Aus
Registration date : 2008-08-01
PostSubject: Re: Air con belt   Thu Nov 05, 2009 12:00 pm
I have the squealing problem to. I have change belts and tighten them and still have problems. Took it to an A/C guy and a mechanic and they can't work out the problem either.
onlypureluck
Number of posts : 12
Home City : west mids uk
Model and year : super custom( living saloon), 3.0td, kzh100, 1994,
Registration date : 2007-12-25
PostSubject: Re: Air con belt   Thu Nov 05, 2009 5:27 pm
got mine from motor factor a while ago, seem to remember i ordered belt for toyota land cruiseror four runner same engine, both usually listed in uk part books, also very tight fit to get on. hope this helps.
steve
PostSubject: Re: Air con belt   Thu Nov 05, 2009 8:29 pm
cheers.... i'll have a look and i'll let you know Phrollins about the squeeling!!
phrollins
PostSubject: Re: Air con belt   Wed Nov 18, 2009 11:25 am
How did you go with the squeeling entwistlea
PostSubject: Re: Air con belt   Wed Nov 18, 2009 4:16 pm
lack of time due to work, so bobbed it down to my mates garage... its in having the windows tinted, extend wheel bolts and this looked at.... starngely enough though, on the 3 min journey to the garage it didn;t squeel !!!
Should get her back on Friday, i'll let you know the outcome
Andy
mr freeze
Home City : Sydney South
PostSubject: Re: Air con belt   Thu Nov 19, 2009 9:36 am
had a pajero once and it only had to look like rain it it would squeel
tried wd40 , soap and then found surf board wax did the trick.
watch your fingers when rubbing wax on the belt, could be painfull
PostSubject: Re: Air con belt   Mon Nov 23, 2009 8:38 pm
Got Bertha back, belt just needed tightening slightly, haven't had chance to try her properly yet, but mate said belt was fine, just needed adjusting !
millab
Number of posts : 7
Registration date : 2008-10-06
PostSubject: Re: Air con belt   Fri Mar 12, 2010 2:21 am
Mine is now squeeking too!
Only seems to happen in humidity. In Canberra it's fine but whenever i'm in Brisbane it squeeks constantly!
I will try tightening the belt and see if that does the trick
Air con belt
» WWII Inflatable Life Belt
» A nice find, but I need help...WWI Hate Belt
» Canadian Boer War Stable Belt?
