 Steering wheel adjustment fuse
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Steering wheel adjustment fuse   Mon Nov 23, 2009 6:31 pm
Power adjustment on the wheel has stopped working, anyone any idea which fuse its on, not obvious from the handbook.....
PostSubject: Re: Steering wheel adjustment fuse   Mon Nov 23, 2009 8:36 pm
Ok, so i've found this much out.... fuse for ECU B was blown..... so it looks like its on this circuit, but with what else i don;t know.... but...
Discovered that the wiring into the driver seat has got caught under the seat and dragged back while it was in the Garage .... ( !!!) this has broken one wire and damaged 2 more..
I changed the fuse before i noticed this and it blew again, then i noticed, disconnected the block to the seat and the fuse is ok...
So at this point i'm guessing that its connected ! The power seat still moved, but it didn't automatically move back when i removed the key, so i'm guessing its on the same circuit and this is whats damaged..... Will have a play later in the week, but thought someone may find this helpful!
Andy
PostSubject: Re: Steering wheel adjustment fuse   Mon Nov 23, 2009 10:35 pm
Cheers fella,always good to know when things go amiss.I dont think things are explained to well so with em being imports its all hit n miss.I have used hilux forums before now and they are sometimes usefull.Good luck keep us all posted.
PostSubject: Re: Steering wheel adjustment fuse   Tue Nov 24, 2009 6:28 pm
going to try and get the wiring diagram if i can, there's a lot of wires for a power seat ! - will let ya know and i'll have a look at the hilux stuff too
Ta
PostSubject: Re: Steering wheel adjustment fuse   Thu Nov 26, 2009 3:16 am
Mine stopped working but it was the cog that had jambed. Pulled it out and gave it a bit of a biff and all is well again. The seat doesn't worry me cause it's back as far as it will go and thats still just a tad shy of comfortable. I must look into moving the rails back a bit one day, there is plenty of room..
Number of posts : 1118
PostSubject: Re: Steering wheel adjustment fuse   Thu Nov 26, 2009 1:51 pm
What are you 10foot 14 !! I must be a short ass.
PostSubject: Re: Steering wheel adjustment fuse   Thu Nov 26, 2009 8:24 pm
Just got long legs. I can't quite stretch out. Bloody comfortable to drive tho
PostSubject: Re: Steering wheel adjustment fuse   Sat Nov 28, 2009 5:08 pm
Managed to get it working, looks like the pink wire on the block into the seat is the hot wire for the steering column motor
Will09
Number of posts : 4
Registration date : 2017-09-24
PostSubject: Re: Steering wheel adjustment fuse   Sun Sep 24, 2017 8:06 am
Anyone end up figuring this one out? Mine has stopped working and doesn't make a noice. When the cogs were jammed, did they make any noice at all when you tried to adjust the wheel? Does anyone know what fuse it is?
» [MF] Tomoko Fuse - Enjoyable Origami to decorate your Living
» VAC " COLA " for 2013 is .... 1.80 % ....BELOW NAT. CPI AVERAGE OF 1.90% ....... Check your mthly Pay
» Monthly Health Premiums
» PIAT practice bomb
» [Origami Book] Tomoko Fuse - Unit polyhedoron origami
