 power steering in the wet
dawncbn
Number of posts : 13
Home City : Hoylake, Merseyside
Model and year : Toyota Hiace, EDI Super Custom LTD Edition 2.5 Auto 1992
Registration date : 2009-05-08
PostSubject: power steering in the wet   Tue Dec 22, 2009 11:17 pm
When I go through a lot of water, heavy rain puddles, the power steering seems to go! Any ideas?
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 11:30 am
Not sure what you mean by 'seems to go'
Aquaplaning?............
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 1:48 pm
if its just for a brief moment i agree it does sound like aquaplaning and the weight of the water on the wheels, its not gone just feels that way....
if its longer and you are def loosing power i'd look at a short somewhere, maybe water getting into the pump?
dawncbn
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 6:04 pm
I mean, the driving goes very heavy just for a few seconds, its very noticacble. I think aquaplaining just goes light not heavy. My mum had a car with no power steering and that was heavy when parking it. That is what I meant, sorry if it was not clear enough.
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 6:10 pm
Is this when your going quickly or slowly? If it at speed ( say over 30mph) then its probably just the weight of the water on the wheels.
The only way i know that power steering would go is lack of fluid in the system, a stretched belt or faulty electrics. First thing to do is check your level of fluid, if its low then it could be the extra strain is causing this, then check the belt to the steering pump, again if this is slack it may be it... i guess its "possible" that water is splashing up from the wheels onto the belt causing it to slip, this is why you're loosing power, but i'd be surprised, unless some protection is missing, inner liner or something?
Finally it could be electrical, but the fact it comes back again, says maybe not...
Have a check of these bits, but ofyou're not sure get a mechanic to look over it, last thing you want is a steering failure at speed !!
Andy
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 9:14 pm
Don't think it will be electrical...at least on my 2.8 its entirely hydraulic...the variable assistance provided by a trachoid pump.
Low fluid or belt slip as Andy suggests.....do you get any banging or grinding noises whilst the power assistance is out?
dawncbn
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 9:31 pm
No, just the steering heavy for a few seconds. My tbelt light has come on though as I went past the magical 100000 km last week
PostSubject: Re: power steering in the wet   Wed Dec 23, 2009 9:39 pm
I'd check out the belts sooner rather than later, sounds like its your problem and ifthey go it could be V pricey !!!!
Elusive
Number of posts : 15
Home City : Tauranga, New Zealand
Model and year : 1994 Supercustom, Lowered on 18" Lenso Mags, 5% Rear Tints 35% Front tints.
Registration date : 2011-02-27
PostSubject: Re: power steering in the wet   Wed Mar 02, 2011 9:58 am
Hey there.
Off topic to do with the SC, but my Hiace work van (3l Diesel - Non-Turbo), does the same thing and I understand what you mean.
You drive through a puddle and after you have been through the puddle the steering becomes heavy, It isn't Aquaplaning as you have already been through the water, it is just after, the work van is going into get the top arms looked at so I will bring the point up and see what they can find. Will post back here if I can find out.
motorwaydrifter
Number of posts : 16
Registration date : 2009-02-03
PostSubject: Re: power steering in the wet   Sat Mar 05, 2011 10:48 pm
Your problem is almost certainly a slack power steering belt. When you go through water the belt slips making the steering heavy. It happens on any vehicle , not just the SC .
» Browning Hi Power Holster
» Canadian Hi Power..... airsoft
» NHS - The McCanns Abuse of Power
