 t/belt light on
dawncbn
Number of posts : 13
Home City : Hoylake, Merseyside
Model and year : Toyota Hiace, EDI Super Custom LTD Edition 2.5 Auto 1992
Registration date : 2009-05-08
PostSubject: t/belt light on   Tue Dec 22, 2009 11:38 pm
Hi, my tbelt light has come on. Found out it is because it has just done the magic 100,000km
I also lost a wiper blade on the motorway, (was on my way to catch ferry, so nice man in Halfords taped a wiper blade on for me, as he said it had sheared off, eroded) Anyhow it works fine but I wanted to get it fixed properly and put a new wipers on plus get the tbelt sorted. So off I went to Toyota. Here is the bill, quote as I haven't had it done yet.
wiper blade, 9.50 each
wiper arm, 45.76
wiper arm, 39.87
timing belt 31.04
336.53 for labour fitting wipers and belt!!!!! I thought that was mad steep.
PostSubject: Re: t/belt light on   Thu Dec 24, 2009 11:54 am
Are you talking about the bit that sticks out of the body work that needs replacing? If so this a aprtial dash out to get access to it job.
Not sure about the T Belt, but I think a fair bit of engine strip down is required to get at it. On the 3.0 it can all be done through the engine hatch.
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Re: t/belt light on   Thu Dec 24, 2009 12:54 pm
Sounds about right price wise. I had my belt done by a mate who runs a garage and it was a good few hours work....
As Clive said, depends on what part of the wiper has broken, you can get blades fitted - yes the fitments are not normal clip on, but my local motor factor had the kit...
Wiper blades - about 16 quid for 2
Fitting kit about 8
Seeing out a clear windscreen - priceless
PostSubject: Re: t/belt light on   Thu Dec 24, 2009 7:12 pm
Quote :
watch too much telly and u/tube Smile
PostSubject: Re: t/belt light on   Wed Dec 30, 2009 3:04 pm
You should be able to get a good local garage to do it for arond the 200 mark.Just ask them to do the wipers while its there.Pays well to use a good diesel mechanic but it should be an easy job for any mechanic.As entwistlea said it is a time consuming job just removing the guards and stuff out of the way aswell as working in the tightest of areas.
onlypureluck
Number of posts : 12
Home City : west mids uk
Model and year : super custom( living saloon), 3.0td, kzh100, 1994,
Registration date : 2007-12-25
PostSubject: Re: t/belt light on   Fri Jan 01, 2010 11:51 pm
timeing belt on 3.0td,1kzte engine takes 2hrs max, it only drives inj pump if i remember correctly, no bottom pulleys involved. in toyo surf job booked at about 1hourish as access easier on pickup. presume you have different layout on your engine
PostSubject: Re: t/belt light on   Sun Jan 03, 2010 5:07 am
I would assume that all the radiators must come out so you will probably be up for a aircon recharge.. Not looking forward to it myself..
PostSubject: Re: t/belt light on   Sun Jan 03, 2010 10:12 am
had my belt done last year and it was done in a couple of hours with a full 100,000 service so i am not sure that the radiators have to come out.
my air con was not regassed at that time and still is loverly and cold
PostSubject: Re: t/belt light on   Sun Jan 03, 2010 10:45 am
My understanding is its a very quick job on a 3ltr...but much longer(more dismantling) on a 2.8/2.4.........
PostSubject: Re: t/belt light on   Sun Jan 03, 2010 12:25 pm
no need to remove rads on the 3ltd, its awkward, but not difficult ( not for an t'belt anyway)
PostSubject: Re: t/belt light on   Sun Jan 03, 2010 7:01 pm
OK I feel better now Smile
jimsmim
Number of posts : 188
Home City : paisley
PostSubject: Re: t/belt light on   Tue Jan 05, 2010 8:48 pm
if its just the small bracket that attaches the blade to the wiper arm via 2small screws ..then this bracket comes as part of the kit when you buy original fitment toyata blades .... like mentioned before less than a tenner each.....how do I know this.... mine rotted through and snapped.... Rolling Eyes
t/belt light on
