 Hiace front suspension
falcon9810
Home City : Kampala
Registration date : 2010-02-17
PostSubject: Hiace front suspension   Wed Feb 24, 2010 2:00 pm
My front suspension is "popping" and seems very loose. I've put in new shocks but can't find any information about replacing the main suspension parts. There are no springs, so does it have torsion bars?? If so can you replace with heavy duty? I live in Africa so the van does a lot of unimproved roads. Any ideas? Does anyone have a good website for parts/service manual for the Hiace?
PostSubject: Re: Hiace front suspension   Wed Feb 24, 2010 8:41 pm
Torsion springs.
Upper and lower steering knuckle ball joints and the inner end bushing can wear. All replaceable.
You need to get the suspension looked at for any movement.
falcon9810
Home City : Kampala
PostSubject: Re: Hiace front suspension   Sat Feb 27, 2010 8:13 pm
That's what I thought. Just couldn't find a parts manual to confirm and my mechanic didn't suggest anything. Many thanks for the feedback!
PostSubject: Re: Hiace front suspension   Sat Feb 27, 2010 9:52 pm
HAve a look here mate for all parts. It wont help you find the parts but at least you know what you are looking for
http://www.toyodiy.com/
Welcome to the forum
dandywarhol
Number of posts : 163
PostSubject: Re: Hiace front suspension   Mon Apr 19, 2010 12:53 am
Does anyone know of a motor factor/supplier of an upper wishbone for a '94 4WD LH129 hiace?
Do any of the UK spec Powervan ones fit?
PostSubject: Re: Hiace front suspension   Mon Apr 19, 2010 10:41 am
Toyota should supply...
You'll notice a 10mm? bolt on top of the upper ball joint....this can be unscrewed, temporarily replaced with a grease nipple and a pump of grease added to the joint. Do it with the vehicle jacked up to allow the grease to fill any void in the upper joint
dandywarhol
PostSubject: Re: Hiace front suspension   Wed Apr 21, 2010 10:02 am
Thanks chris - already did that -
I've ordered a new one from Toyota - almost 300! Fortunately the company who passed it as safe at the MOT test are contributing heavily towards it when - fair play to them, the Motor Trade has taken a fair bit of knocks but this company have come up trumps - thumbs up to Crosbie and Bateman in Kirkcudbright in Dumfries & Galloway.
PostSubject: Re: Hiace front suspension   Tue May 11, 2010 2:40 pm
Hmmm interesting Sleep
I have installed grease nipples on these as well, prevention better than cure. Although i have noticed a thud sound if i steer the van side to side or if i go over rough ground, its like a delayed thud as the weight of the van shifts? The CV's are good and wheel bearings seem ok, Its been like it for about a year now but got worse to the point where i gotta fix it before i go crazy! What a Face Thought it might even be in the steering rack? But cant really feel it on the wheel that much? Will jack it up on the weekend and have a proper Captain Cook i think. I did notice that the front sway bar rubbers are looking pretty sad but shouldn't cause the noise i hear. Any one had anything like that? Shocked
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Re: Hiace front suspension   Tue May 11, 2010 7:12 pm
i'd go with perished bushes ?
PostSubject: Re: Hiace front suspension   Tue May 11, 2010 11:32 pm
Mine makes 'squelchy noises' when it 'bounces' round corners....not sure why...
PostSubject: Re: Hiace front suspension   Wed May 12, 2010 7:10 pm
hmm, either you're sitting on your sandwiches or it could be shocks are leaking and on their way out ?
PostSubject: Re: Hiace front suspension   Wed May 12, 2010 8:02 pm
Yes, I do peer at them periodically for signs of leakage...but nothing yet. Can't make it squelchy by rocking it stationary.
Maybe its the shocks... or the bushes squeeking in the anti roll...maybe the rubber stop bottoming out on the lower wishbone...time will tell I suppose Rolling Eyes
PostSubject: Re: Hiace front suspension   Wed May 12, 2010 8:03 pm
worth giving it all a decent squirt with some lubricating fluid ?
» Daily Express front page
