 Front break disks
moogdrew
Number of posts : 62
Home City : Melksham
Model and year : 1993 Hiace Super Custom Limited 2.8D (LH107)
Registration date : 2007-02-17
PostSubject: Front break disks   Sun Jul 01, 2007 11:29 am
Hi - has anyone changed the front brake disks on a hiace yet - i have to change mine soon and wondered if any one can give me a breif description of what i'm gonna find.
I have noticed that they are on the back of the hubs so does this mean that i will have to dismantle the wheel bearings to get them off?
(I have a 1993 2.8l (3L engine) super custom ltd)
room101
Number of posts : 90
Home City : Torbay
Registration date : 2007-03-21
PostSubject: Re: Front break disks   Sun Jul 01, 2007 8:44 pm
Is yours a 4x4..
moogdrew
PostSubject: Re: Front break disks   Mon Jul 02, 2007 12:34 pm
Yes - with freewheeling hubs
MNC
Number of posts : 101
Model and year : 1996 SC LTD 3LDT
Registration date : 2009-09-21
PostSubject: Re: Front break disks   Wed Aug 04, 2010 4:55 am
Im thinking of upgrading my brake system by replacing my discs with slotted rotors and good pads. anything i need to know or anyone already done this?
PostSubject: Re: Front break disks   Wed Aug 04, 2010 11:17 am
Yes you have to remove the hubs to unbolt the disk from the back of the hub.
I've stock ventilated ones on and they are very good considering the weight of the bus.
hiacenewbie
Home City : Melbourne Victoria Australia
Model and year : 96 hiace 2.4 carby engine
Registration date : 2010-08-04
PostSubject: Re: Front break disks   Wed Aug 04, 2010 2:02 pm
Hi guys,
First of all, I have a normal Hiace van with a 2.4L petrol engine and not a super custom.
I have tried other toyota forums but not much help.
So I hope you guys can help me out if the front brake setup is similar to a normal hiace.
I have bought a pair of brake pads and discs. After taking the wheel off, I realised that the brake disc is behind the hub. What are the steps in order to remove the hub and disc ?
PostSubject: Re: Front break disks   Wed Aug 04, 2010 4:05 pm
4WD is a bit complicated and I've not done it.
2 or RWD as it should be known - remove wheel, hub cover, split pin and castlelated nut, undo and slide off the brake calipher(hang it out of the way mind the flexi hose), carefully pull the hub and disc off be careful of the bearings dropping out and dirt.
Replace disc and pack hub with grease refit and job done.
Hub nut done up until the hub binds slack off until you have acces to put the split pin in and double check.
HTH
Front break disks
» Daily Express front page
