 P1220
zaz
Number of posts : 6
Home City : Barbados
Model and year : 2002 Grand Cabin KZH120
Registration date : 2010-03-16
PostSubject: P1220   Fri Mar 19, 2010 4:46 pm
Hello all, I am new here so if i am doing something wrong pls. help me.
I have a 2002 Grand cabin G 3000cc KZ1 engine. recently, my check engine light has been showing up, usually when the engine is at low revs (-1000 rpm). when this happens,the engine also makes a kind of knocking sound. if i rev a little, the noise goes away and the light goes out. the diagnostic reading says "timer circuit malfunction P1220". Any ideas?
PostSubject: Re: P1220   Fri Mar 19, 2010 7:17 pm
Welcome mate. I'm afraid I can't help with your problem tho.
VOZZA
Number of posts : 150
Home City : SYDNEY
PostSubject: Re: P1220   Fri Mar 19, 2010 11:15 pm
I get it once in a blue moon for about 30 seconds, my theory is bad quality fuel and the engine goes into limp home mode.
zaz
Number of posts : 6
PostSubject: Re: P1220   Sat Mar 20, 2010 1:43 pm
Sounds interesting. I live in the caribbean and there r many complaints of poor fuel quality. is there an additive that can enhance it?
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Re: P1220   Sat Mar 20, 2010 7:41 pm
sounds like its struggling to run and the knocking sounds like pre ignition.. bad fuel would do this, put some decent stuff in and give it a good blast, if this doesn;t help then start thinking about sensors....
PostSubject: Re: P1220   Sat Mar 20, 2010 11:02 pm
Have you had any work done recently?Could be this.
zaz
Number of posts : 6
PostSubject: Re: P1220   Sun Mar 21, 2010 12:53 pm
No work was done on the vehicle. On the island there is only one grade of petrol. I always use Esso as it gives better mileage with my gasoline vehicle. I will switch to
shell for a while n see how it goes.
Another thing i've noticed is, when i am idling and running a/c, the revs hardly increase when the compressor cuts in and the engine labors until it cuts out again.
zaz
Number of posts : 6
PostSubject: Re: P1220   Tue Mar 23, 2010 1:00 am
I know it is a bit soon, but after 3 days of using another brand/quality fuel, i've had no occurances of my former problem; (knock wood) I will continue to monitor through a few tank refills and see.
PostSubject: Re: P1220   Tue Mar 23, 2010 7:03 am
Good, if you think that there is water in the fuel you can add a little bit of metholated spirits to it and that helps to counteract the water.
P1220
