 help 1991 2ltr td auto (heaters cold/revs/fan belts)
Twoesme
Number of posts : 12
Home City : caerphilly south wales uk
Registration date : 2010-04-01
PostSubject: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Tue Apr 06, 2010 9:17 pm
1st is the heaters ,i ve toped up the rad ,the water seems hot in the pipes to touch,the engine running at middle temp ,but the heaters only come hot now and again ,not constant on the dails
2nd rev counter ,when i start the engine the rev counter lifts and works sweet,i can rev it up and it warks sweet but after a min or so it just drops back down as if the engine is not started ,checked some fuses under the heaters and a few regulators but after a good wd40 its still the same,dont know how it works ?
3 rd were is the bloody altinator so i can tighten up the fan belts ?
its a 1991 2lt td auto
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Tue Apr 06, 2010 10:02 pm
I'm guessing its not been used a while?
Anyway...alternator...front offside wheel arch....look through / lift the rubber at the side of the engine bay and you will see a 10mm bolt that adjusts the alternator swing.
Basically...its under your backside.
Rpm meter...the only time that happened to me was due to condensation / moisture behind the dash...it sorted itself out eventually
Heaters...all you can do is check the heater valves....though it sounds like it may be holding a lot of air...front valve sort of visible through the front grill.......rear valve..follow the pipes under the van / offside below the side heater matrix rear switch...unless I'm misunderstanding and you are talking about the heater motors/blowers
Twoesme
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Tue Apr 06, 2010 10:19 pm
yes its got moss in the window rubbers so yore on the monney its been standing a while ,thanks for the advice mate ,yes the heater blowers are cold then hot .
these valves let the air out yes?
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Wed Apr 07, 2010 12:27 am
No, the valves just regulate the coolant flow to the heater matrixes.
To get air out open the heater valves, clamp the expansion tube and run for 1/2hr with the coolant filler cap off...if you can raise the head of the filler, so much the better...rev it now and then to jolt/shock any trapped bubbles round
Twoesme
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Wed Apr 07, 2010 12:56 am
cheers my friend i,ll do it 1st thing 2moz
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Thu Apr 08, 2010 4:48 pm
think Chris is on the money here
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Fri Apr 09, 2010 1:52 am
I always run both heaters on high when filling the radiators from scratch just to make sure any air in heater cores gets purged. Just another way of saying what Chris said ..
Twoesme
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Fri Apr 09, 2010 11:50 am
update'''@ it was a night mare to get at the bolt to adjust the altanator,mine was a 14 mill,now the bloody powerstearing belts are loose and i cant see them agjusters either.
we have decided to turn her into a 2 berth camper,i put 35 of diesel in it and done 329 miles untill the red light came back on so thats pritty good around 40-45 i think mpg
the bottom is solid and i,m gong to oil spray it today all underneath,i couldnt get at the power belts so i sprayd them with anti squeel belt spray i bought off ebay and its done the trick.
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Fri Apr 09, 2010 4:07 pm
You need to unbolt the drivers seat, peel back the carpet and remove the panel under it to get better access to the belts...if you have a cordless drill to unwind the bolts (14mm I think) its only a 5 minute job after you've done it once.
I used the anti belt slip spray once....took it off the next day with meths Rolling Eyes
Working in the engine bay is the only time you miss a bonnet! lol!
Twoesme
PostSubject: Re: help 1991 2ltr td auto (heaters cold/revs/fan belts)   Fri Apr 09, 2010 4:20 pm
all the gears leves seems bolted to the pannel though ! mines auto like
» Effects Of The Cold War Era In Canada
» JonBenet Ramsey - cold case
» Canadian Military During the Cold War
» Baby Hope, Found Deceased 7/23/1991, New York
