 Consol Lid Problem
mr freeze
Home City : Sydney South
PostSubject: Consol Lid Problem   Fri Jun 11, 2010 12:16 pm
Hi , has anyone else had the problem of the consol lid falling closed on level ground , is there some kind of spring thing missing from mine or is that how they are.
Real pain as it would not l not stay open if its life depended on it.
\And how do you get rid of that anoying beep when you put the key in the ignition.
Only 2 dramas I have with this hiace.
Not Bad Van Man !!!! cheers
dandywarhol
Number of posts : 163
PostSubject: Re: Consol Lid Problem   Fri Jun 11, 2010 5:26 pm
See my post re. reversing bleeper/buzzer
Re. the key beep - 2 wires feed up to a sensor in the ignition switch - snip one!
PostSubject: Re: Consol Lid Problem   Fri Jun 11, 2010 11:41 pm
You talking about the engine cover?
If you are there is or should be a plactic strap hidden by the seatbelt that hooks on to the side over the cover.
mr freeze
PostSubject: Re: Consol Lid Problem   Sat Jun 12, 2010 11:29 am
Hi Clive,
not engine cover, glove box between seats called a consol where you put all your crap.
This lid appears to open to 90 degrees and falls shut too easily on level ground.
Ok when parked on a steep hill , stays open real good. confused
PostSubject: Re: Consol Lid Problem   Sat Jun 12, 2010 2:39 pm
Quote :
Are you sure that the bottom of the 'stays' are not impeded by the crap in the bottom of the box......the only time it happens to me is when the stay bottom snags on some of the stuff I never get to see..
PostSubject: Re: Consol Lid Problem   Sat Jun 12, 2010 11:21 pm
Is that where I have my hot/cold box?
PostSubject: Re: Consol Lid Problem   Sun Jun 13, 2010 12:13 am
Yes I think so....we have a 'glove box' between the seats....its 2010 (air con/heaters etc)... is it still called a glove box?
PostSubject: Re: Consol Lid Problem   Sun Jun 13, 2010 11:24 am
Ah right, with you, still use the box for storage when not in use.
PostSubject: Re: Consol Lid Problem   Sun Jun 13, 2010 8:56 pm
Still a glove box here Smile Damn good arm rest when driving...
Consol Lid Problem
» SCM Music Player Problem
» Webmail problem
