 Brake Pads & Filters - A Few Tips
Number of posts: 148
Home City: Lincoln England
Model and year: 1993 Hiace Campervan 4WD 2779cc Diesel Auto Transmission
Registration date: 2007-07-17
PostSubject: Brake Pads & Filters - A Few Tips   Sat Jul 21, 2007 10:05 am
I have a 1993 2.8ltr Diesel Hiace Campervan - LH119
FOR INFO FOR ANYONE GETTING THEIR HANDS DIRTY AND DOING A BIT OF SERVICING Front Brake Pads Kit Part No 04465-YZZAD - Handbrake on Chock Wheels Jack Up Take off wheel , Replacing is a doddle 14mm Ring Spanner to get the two caliper bolts out. Tie Up the Piston Assembly. Prise off the pads from the caliper frame - - place the shims on the new pads & replace Bobs Your Uncle! You may need to press in the Piston using plumbers pliers to refit the Caliper Frame with the piston.
Air filter - behind the Offside Front Wheel - unscrew the Butterfly nut, remove Filter End Housing with rubber seal, unscrew another butterfly nut & remove filter. Part No 17801-54100. Be careful you don't damage the plastic Resonator - next to the air filter (it has 2 rubber flaps on it)
Oil Filter Part No 15600-41010 Diesel Engine Oil Filter is on Right Side of engine- remove front plate/sump guard, use a filter chain with socket housing/3/8" drive - it makes it a lot easier than trying to puncture and rotating with a screwdriver.
Fuel Filter - Diesel is on Left Side of engine mounted on the body - use 12mm socket to remove whole assembly Part No 23303-64010.
Changing Oil (Diesel) by removing sump plug with 14mm socket - you don't need to remove the sump guard - the nut is visible through a rubber sheath.
Number of posts: 1079
Home City: Bristol. U.K.
Model and year: 1995, 3lt Auto
Registration date: 2007-01-15
PostSubject: Re: Brake Pads & Filters - A Few Tips   Sat Jul 21, 2007 10:41 am
Good work M8.. thnx for the info
skyking
Number of posts: 16
Registration date: 2007-05-23
PostSubject: Re: Brake Pads & Filters - A Few Tips   Thu Jul 26, 2007 2:14 pm
Thanks. I'll be changing the filter and oil very soon. This came in handy.
» Chandivert Champion tips
» TIPS/RAHSIA LULUS TEMUDUGA KERJA KERAJAAN
» REAR DISK BRAKE SET RM450
» EVO UPGRADED BRAKE KIT FRONT - USE WITH 17x8J ET25 TOMBINOS
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
