 Oil cooler
hathan
Number of posts : 52
Home City : birmingham
Model and year : 1994 Hiace Super Custom
Registration date : 2010-06-12
PostSubject: Oil cooler   Sat Jun 26, 2010 7:48 am
hi pips has anyone fitted a oil cooler and auto transmission cooler in ther SC's....or can it be done is ther enough room to do that....
PostSubject: Re: Oil cooler   Sat Jun 26, 2010 12:58 pm
Already fitted on mine.
Oil cooler onside of the engine under inlet manifold, auto box cooler part of the main rad.
hathan
PostSubject: Re: Oil cooler   Sat Jun 26, 2010 5:20 pm
what did yours come standard, or did you fit it on yourself....and auto box cooler is the rad, but wouldn't it be better if i put a specific one on....
PostSubject: Re: Oil cooler   Sun Jun 27, 2010 10:25 am
All as standard.
Depends on what you want to do, off road or heavy towing yes and all you would need to do is plumb into the existing pipe work, otherwise it is fine as it is.
I suspect you have the auto box cooler, look for two small bore metal pipes coming from the box.
Not sure about the engine oil cooler on your engine may only be the housing for the filter so not very effective?
hathan
PostSubject: Re: Oil cooler   Sun Jun 27, 2010 2:29 pm
basically im gona be driving to morocco and spain, and at some point im gona be going to Pakistan overland..... so i thought i'l add the oil cooler on, but saying that im not even sure if i have already got one.....it dont seem like it.....does the oil cooler help in a big way....my SC is pretty fast.....
PostSubject: Re: Oil cooler   Sun Jun 27, 2010 10:03 pm
What engine is it?
Should be easy to divert oil feed from somewhere and position the cooler behind the bumper.
hathan
PostSubject: Re: Oil cooler   Sun Jun 27, 2010 11:39 pm
mine is a 3.0td but it moves like a car not a van....no lag watso ever....do u know if these engines run hot in comparrison to normal engines sitting at the front...
Oil cooler
» Are you near Ashburn VA & need a large cooler for shipping?
» nice styrofoam cooler free to a good home - pick up on UWS
