 Check your AC idler pulley
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Check your AC idler pulley    Sun Jun 27, 2010 1:16 pm
Been having problems with what i thought was a loose AC belt, was squeeling like a stuffed pig when i turned on my AC ( which is a lot at the mo), i tightened it up, which didn't help but as a result the belt finally deteriorated, when i took it off a lot of rubber was missing.... so one new belt purchsed and fitted ( easy job)....
However when i fitted and tightened it up and checked the system there was still this random squeeling, but because this time i had the hood cover up i discovered it wasn't the belt, infact it was the idler pulley ( adjuster), the bolt holding the idler wheel to the mechanism was working loose and it was this vibrating that was causing the squeel...
I've tightened up and all is good, however it isn't a lock nut, so probably needs to be kept an eye on, if it was to come loose... A) you'd never find it and B) that belt flying off could make a real mess of the fan and water pump...
Prob worth checking out everyone, its easy to spot, pretty much top of the engine with the cover open !
PostSubject: Re: Check your AC idler pulley    Sun Jun 27, 2010 9:54 pm
On the Townace it sticks out the bottom and is often seized solid.
So thanks not something I'd of thought of checking, even when ajusting the tension.
dandywarhol
Number of posts : 163
PostSubject: Re: Check your AC idler pulley    Sun Jun 27, 2010 11:19 pm
Replaced the bearing in mine recently - if it rocks" then best replaced - its a common on for about a fiver from bearing specialists
gonzo1963
Number of posts : 12
Home City : Newcastle NSW
Model and year : 1995 SC Limited 3.0L TD 4WD
Registration date : 2011-07-11
PostSubject: Re: Check your AC idler pulley    Mon Aug 15, 2011 5:16 pm
I was having a similar problem with my Van, once the belt was tightened it was ok for a minute then i noticed the A/C Compressor was locking up and siezing causing the belt to squeal and smoke. Have to try and get a AC Comp now. will try www.importmonster.com.au.
vanmobile
Number of posts : 55
Home City : North America
Model and year : 1992 3L
Registration date : 2016-04-21
PostSubject: Re: Check your AC idler pulley    Mon Aug 07, 2017 3:48 pm
Using this website japanparts , can somebody help me find the part number for the idler pulley?
http://japan-parts.eu/toyota/jp/1992/hiace-regiusace/lh123v-erpds/4_711140_117_/tool-engine-fuel?short=&sh=idler&ok=OK
Number of posts : 588
PostSubject: Re: Check your AC idler pulley    Mon Aug 07, 2017 10:42 pm
I think you mean this one? (if you mean the A/C idler pulley)
http://japan-parts.eu/toyota/jp/1992/hiace-regiusace/lh123v-erpds/4_711140_117_/electrical/8719_heating-air-conditioning-compressor#88420
vanmobile
PostSubject: Re: Check your AC idler pulley    Tue Aug 08, 2017 4:31 pm
Thaaat's right!! Thanks buddy!!
» VAC " COLA " for 2013 is .... 1.80 % ....BELOW NAT. CPI AVERAGE OF 1.90% ....... Check your mthly Pay
» Check Fraud Case - Possible Plea Deal
» Spell check & word count when posting
» Check your World War One medals
» Two women 'caught trying to smuggle dead relative on to passenger jet at Liverpool airport'
