 Loss of power and cutting out
stevem2727
Number of posts: 3
Home City: surrey
Registration date: 2010-06-26
PostSubject: Loss of power and cutting out   Sun Jun 27, 2010 10:56 am
Hi Guys as you can see this is my first post and unfortunatley its with a mechanical problem.Ive had my super custom for about 4 months now and done 3500 miles with no problems at all until last weekend.It is a 1997 3.0 td auto.The problem started a week after it had been serviced.I went to accelerate and the engine management light came on the van juddered and slowly cut out.It started straight away and drove for another 200 metres or so and then did exactly the same.This continued for a little bit until i found a convenient place to stop where it wouldnt rev at all just cut straight out.I called out the recovery firm and when they arrived 40 mins later everything was ok again so he followed me down the road for about a mile and it cut out again,after headgasket checks and alternator charging checks which were all o.k he thought the fuel pump housing might be sucking in air after just being serviced so tied a rubber glove around the top and away it went no problems,we did 90 miles to get home.i ordered a new part at £140 from toyota and waited.Used the van all week no problems until friday and it did it again.got the van to the garage and they fitted the new part but it was exaxtly the same.So basicly the van now dies out after about .5 mile restarts easily and then cuts out again a few hundred miles down the road.If you leave the van for a few hours you will be able to do 2 or 3 miles before it cuts out again.The whole family are all missing being able to use it and im just looking for some advise on this please,thanks in advance,cheers steve.
Number of posts: 625
Home City: Bristol UK
Registration date: 2008-11-05
PostSubject: Re: Loss of power and cutting out   Sun Jun 27, 2010 6:59 pm
Does sound like fuel starvation. Have you run it to near empty?
If you have a fuel can try connecting a hose direct to the fuel filter and see if that resolves it. If it does then I'd suspect the pick up filter in the tank or an air leak in the delivery hose. If it does not then it is filter/pump and/or electrical problem
stevem2727
Number of posts: 3
Home City: surrey
PostSubject: Re: Loss of power and cutting out   Sun Jun 27, 2010 7:11 pm
Hi there,thanks for your advice funny you should mention running low on fuel,about 3 days before it happened i did get very low on fuel.Is the filter in the tank quite easy to get to do you no.Thanks again,cheers steve
dandywarhol
Number of posts: 163
Home City: Edinburgh, Scotland
Model and year: 1995 LH129V 2.8 Superlong semi hi top campervan 4WD with Mitsubishi turbo
Registration date: 2010-01-26
PostSubject: Re: Loss of power and cutting out   Sun Jun 27, 2010 8:13 pm
If it was serviced did they replace the fuel filter in the engine bay? An incorrectly sealed fuel filter will draw air and give the symptoms you're talking about..................
Sounds like the garage need to sort out THEIR problem and refund you £140!
Number of posts: 324
Home City: Sandhurst, UK
Model and year: 1996 Super Custom Ltd. 3.0 TDI EFI
Registration date: 2009-09-19
PostSubject: Re: Loss of power and cutting out   Sun Jun 27, 2010 8:19 pm
yep, sounds like a filter prob. May even have been fitted the wrong way round !!!
Number of posts: 466
Home City: Preston
Registration date: 2008-11-18
PostSubject: Re: Loss of power and cutting out   Sun Jun 27, 2010 8:49 pm
Home City: Preston
PostSubject: Re: Loss of power and cutting out   Sun Jun 27, 2010 8:52 pm
chrisandhiace wrote:
Not fully understanding ecu etc. I was thinking fuel filter/blockage too.....You'll usually get a period of terrible performance before it dies though.
If the tanks run very low it can suck some otherwise undisturbed crap up to the filter
Another long shot on very old rubber tubes is them sucking shut when they get too rubbery....97 is not really old enough for that though....
» Blood Loss!
» Rancho del Oro power out?
» cobra power pro
» How to Convert the PORSCHE 924 / 944 to V8 power
» Stuck....and loosing will power!!
