Dane
Number of posts: 16 Age: 63 Home City: Hibberdene, KZN, South Africa Model and year: 1994 Toyota Hi Ace Super Custom 3L Turbo Diesel full time 4x4 Registration date: 2010-04-03
 | Subject: Wheel Bearing replacement 4x4 Super Custom 3L diesel ... Mon Jun 28, 2010 11:08 pm | |
| HELP! Can anyone give directions on how to replace a front wheel bearing on a 1994 Hi Ace Super Cusom 4x4 diesel 3L?? |
 | Subject: Re: Wheel Bearing replacement 4x4 Super Custom 3L diesel ... Tue Jun 29, 2010 6:35 am | |
| I'd browse below before starting... http://www.4x4wire.com/toyota/maintenance/front_end/teardown/ |
 | Subject: Re: Wheel Bearing replacement 4x4 Super Custom 3L diesel ... Tue Jun 29, 2010 10:46 am | |
| Yeah this look's spot on! Thought i'd have to do this to mine but as it turned out it only needed a small adjustment. For ages i had this thud noise when going over bumps or around corners, thought it was a dud ball joint or bushing or wheel bearing? Eventually found that the front wheel bearing was just a bit loose, got my mechanic mate to adjust to correct tension. All is well again! |
Dane
 | Subject: Front wheel bearing replacement Wed Jun 30, 2010 12:11 am | |
| Hi all: thanks. Managed quite easily with the replacement: actually a very simple procedure. Took all of 1.5 hours from start to back on the road. Nice little job for pre-breakfast exercise! |
