 sticky clutch pedal
redcore4
Number of posts: 13
Home City: Manchester
Model and year: super custom 2.4TD manual - 1992
Registration date: 2010-05-08
PostSubject: sticky clutch pedal   Sun Jul 04, 2010 7:53 pm
Drove my van for about 100 miles this afternoon coming back from a camping trip. When I got back, my clutch pedal started sticking in the down position. I have to lever it back up with my foot in order to use it. This doesn't happen on every gear change, just one or two in every four or five changes. Any ideas what i can do about it?
Number of posts: 466
Home City: Preston
Registration date: 2008-11-18
PostSubject: Re: sticky clutch pedal   Sun Jul 04, 2010 9:06 pm
If its a hydraulic clutch I'd be considering hydraulics...maybe the slave cylinder.
Seal kits should be available 'if' thats the problem....
Another... (if its cable operated) is a stretched cable....if there's no way of adjusting - a shim can be made with some thought...untill cable is replaced.
Other than that....clutch return springs or dunno......
Number of posts: 625
Home City: Bristol UK
Registration date: 2008-11-05
PostSubject: Re: sticky clutch pedal   Mon Jul 05, 2010 7:21 pm
Pedal has a spring to return it, give it a spray of WD40 or something like that and see if that helps.
If not I'd suspect the master cylinder piston. seal set easy to get and do but a real pain to get at it!
redcore4
Number of posts: 13
PostSubject: Re: sticky clutch pedal   Fri Jul 09, 2010 6:54 pm
a spray of WD40 seems to have partially solved the problem - now it's only sticking every tenth time or so.. suspect another squirt will do it. cheers!
plus i think it's a cable clutch, not hydraulic.
Number of posts: 324
Home City: Sandhurst, UK
Model and year: 1996 Super Custom Ltd. 3.0 TDI EFI
Registration date: 2009-09-19
PostSubject: Re: sticky clutch pedal   Fri Jul 09, 2010 9:50 pm
might want to give the piston a clean, if you can get around the rubber boot even better, grease and crud on the piston may not be helping, same around the pedal pivot, where they are greased, grit and dust collects and starts to cause problems
sticky clutch pedal
» Sticky: For spotted
» Centrifugal clutch idea.
» clutch for 2001 indian scout
» sticky clutch pedal
» stiff clutch pedal
