 Tightening rear door window wiper....
MNC
Number of posts : 101
Model and year : 1996 SC LTD 3LDT
Registration date : 2009-09-21
PostSubject: Tightening rear door window wiper....   Wed Jul 28, 2010 2:28 am
Hi team,
anything i need to be aware off while trying to tighten the wiper thats fixed to the rear door? is there a need to get on the inside of the rear door ie: pull off the rear door skin?
Cheers in advance
PostSubject: Re: Tightening rear door window wiper....   Wed Jul 28, 2010 12:07 pm
If the spindle is loose I think the nut on the out side can be tweaked. If you need to get at the motor mounting bolts then yes the interior door card/trim needs to be removed.
MNC
PostSubject: Re: Tightening rear door window wiper....   Sun Aug 01, 2010 9:44 am
found out what the problem was. the larger nut that holds the assembly on to the rear door had thread over time making it pretty loose. i couldnt find an exact replacement at the wreckers but i manage a temporary fix by pulling a part off the rear wiper assembly from a toyota estima. the wiper only goes about a half wipe on the back window but will do till i source a hiace part. :-)
heres some pics to explain
» McCanns abduction theory goes out of the window!
» Facebook quick link app - have your forum inside Facebook window
» WHAT ABOUT THE WINDOW - By Pat Brown
» death to a paedophile
