 Cam/timing belt replacement
johnny
Number of posts: 9
Home City: A CAMPSITE NEAR YOU
Registration date: 2008-03-09
PostSubject: Cam/timing belt replacement   Tue Aug 10, 2010 9:40 am
Please could any one tell me if its is just a straight belt change or is there tensioners etc that need to be done also would you change the water pump? ps its N/A 2.8 ive had her nearly 5 years now i know it was done at 100000km there is a sticker on the rocker cover she now has 150000 many thanks johnny
Number of posts: 625
Home City: Bristol UK
Registration date: 2008-11-05
PostSubject: Re: Cam/timing belt replacement   Tue Aug 10, 2010 12:07 pm
100,000 Kms or 5 years is the recommended change interval.
Not done a 2.8 so don't know the answer to the other questions.
Number of posts: 466
Home City: Preston
Registration date: 2008-11-18
PostSubject: Re: Cam/timing belt replacement   Tue Aug 10, 2010 7:17 pm
I've not done it...but looking at manual there is an adjustable untoothed idler tensioner....
Its a one peice timing belt cover....so I'd guess all the belts, fan and external pulleys need to come off to allow its removal.
Book says every 60,000 miles
I think the 3L engine repair manual was online at a hilux/surf site somewhere
I'd be inclined to put a new water pump on at the same time.....
The engine manual is 'toyota rm123e'
Quick search shows some ' torrents' ..but I'm not sure how to use them
Home City: Preston
PostSubject: Re: Cam/timing belt replacement   Tue Aug 10, 2010 7:50 pm
2L, 3L engine repair manual here
If you click file..then save as...saves as pdf.
Strangely, this does'nt have the timing belt section as in the aug 88 version...(its a supplement)
http://www.toyota4wd.dk/Teknik/J70/Toyota%20Motor%20Manual%202Lt.pdf
» Timing for combat?
» V-Belt apa paling bagus k scooter2, trutama ego?
» TIMING BELT REPLACEMENT
» timing belt and water pump replacement...
» Cam/timing belt replacement
