 Removal of head lights with pics and HID Install
Goto page : 1, 2  Next
mattyj
Number of posts: 118
Home City: Liverpool Sydney
Model and year: 92 Toyota Hi-ace 4x4 Super custom non turbo
Registration date: 2010-08-05
PostSubject: Removal of head lights with pics and HID Install   Thu Aug 26, 2010 6:54 pm
Hello All
Just wanted to help out all the newby's trying to remove the headlights to change the globes and or convert to HID
"Thanks to "moogdrew" for helping with info"
First you have to take both the indicators out - this is done by removing the screw on the back of the indicator in the door pillar,
Removing the indicators by pushing the black clip out from behind.
Be careful ease it out
held in here with a lug
Then you have to remove both the sidelights - they are held in by one screw behind the indicator that holds the chrome trim that the sidelight is set in to - you have to push them forwards from behind too.
Very gently pulling and pushing forward
Now you can get to the screws that hold the top of the grill/front panel on (on the end of the thin bits that go over the headlights)
once you've removed the screws the rest of the grill is held in by a row of about 5 plastic clips along the bottom of the grill so you have just got to pull gently and hope! - mine is now held in by zip ties lol
Once the grill is off the headlights are removed with 4 bolts.
Bottom left
Bottom Right
Top Right
Top Left
***** HID Install pics will be uploaded when the HID lights turn up in the next few days and if i feel up to it i might even do a comparrision of 55/60w standard 90/100w phillips and 55w 43000k HID*****
The headlight bulbs are standard H4 55/60w
The fog-light bulbs are H3C 55w
You can use a standard H3 fog-light bulb you just have to add a wire to the bulb holder to plug in to the negative on the connector
dandywarhol
Number of posts: 163
Home City: Edinburgh, Scotland
Model and year: 1995 LH129V 2.8 Superlong semi hi top campervan 4WD with Mitsubishi turbo
Registration date: 2010-01-26
PostSubject: Re: Removal of head lights with pics and HID Install   Thu Aug 26, 2010 7:06 pm
Thanks, good post! It's a helluva carry on to remove lamps eh? but worth doing, as I found bulbs and a loom for the fog/day light - even the relay was there - I just had to add a switch Smile
Number of posts: 857
Home City: Hervey Bay Qld
Model and year: 1994 sc
Registration date: 2008-08-15
PostSubject: Re: Removal of head lights with pics and HID Install   Thu Aug 26, 2010 9:28 pm
Well done that man, take a pint out of petty cash Smile
Number of posts: 1079
Home City: Bristol. U.K.
Model and year: 1995, 3lt Auto
Registration date: 2007-01-15
PostSubject: Re: Removal of head lights with pics and HID Install   Fri Aug 27, 2010 8:09 am
thats what i'm talking aboout !!! good work fella
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Fri Aug 27, 2010 9:15 am
next few
Dash removal
Stereo install
Alarm install
Reverse lights
Any other ideas just let me know and i can have a go
loving my 8mp camera phone lol
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Aug 30, 2010 3:25 am
Ok HID install
Head lights / grill removed
Removed Parts
Back of head light
Again
Globes old and HID
Globe installed
Boot cover installed modified
Wireing spread out
Earth point
Old headlight clip to new plug and play clip
Head light hooked up
Ballast mounted (bad pic forgot to take pics till i put lights back in)
Ballast and relay
Positive through the firewall
Positive run up the passenger side to the battery
Off Day
Low Day
High Day
Night pic will be taken tonight cant wait lol
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Aug 30, 2010 3:52 am
Tool List
Philips head Screwdriver
Flat head screw driver
Zip ties
Wire Cutters
Soldering iron
Tape
Socket 10mm
Socket 12mm
10 mm spanner
wire strippers
i think thats it lol
3 hrs work and less then $120 for HID and led globes (waiting for led globes to turn up for blinkers and park lights)
Number of posts: 450
Home City: AUS
Model and year: 4wd sc
Registration date: 2008-06-04
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Aug 30, 2010 10:26 am
Nice work mate!!! Hay what type of H4 HID did you go for? Just single Hid with no hi beam? or Halogen/Hid hi/lo beam or even solenoid operated hi beam from the look's of it in your pic's?
I converted my fog lights to HID but not really sure if it's the way to go with my main lights. Let us know what you think after driving at night? - Brightness and quality of the beam pattern?
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Aug 30, 2010 11:17 am
OMG Night driving is now so good
went to soccer tonight and i have to admit i need to adjust the lights but its so good
people kept flashing me one guy (4wd) put his high beams on at me so i did the same and i could see his hand in front of his eyes at about 20mts away so they work great
So impressed i want to do HID in the driving lights im getting
i went for 55w 43000K 12v Hi / Lo (ebay item 220655195662)
Sorry ppl im not trying to sell them lol
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Sat Sep 04, 2010 1:18 am
ok night time pics
Drivers seat
Low beam
High beam
Looking at the van
Low
High
Side on
PostSubject: Re: Removal of head lights with pics and HID Install   Sun Sep 12, 2010 4:49 pm
good work and thnx for documenting it ..
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Sun Sep 12, 2010 6:31 pm
thats no problem
it now has a good set of spotties on it to that will be upgraded to HID soon lol
Home City: AUS
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Sep 20, 2010 4:13 am
These are my fog lights that i changed to HID - 3000k colour temp - good in the fog! Wink
mattyj
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Sep 20, 2010 5:01 am
Nice very nice
I wouldn't mind get a bumper bar like yours with the lights in it so i dont need to have the hid's on during the day on back rds for safety
dandywarhol
PostSubject: Re: Removal of head lights with pics and HID Install   Mon Dec 06, 2010 10:20 pm
Hi matty - are the h3 and h3c the same fitting in the lamp i.e. a half round and square cutout to fit into the headlamp shell? - and you only need to solder an earth wire onto the bulb?
Page 1 of 2Goto page : 1, 2  Next
» How to: Install 9005 bulbs in your 9006 low beam sockets
» DIY IACV Removal/Cleaning
» Paintless Dent Removal
» A few pics of my junk
» steeltex pics
