Hi, all, after 3 years of trouble free running my 3lt turbo suddenly cut out today. No warning lights or check engine before stop. Symptoms are,after stopping & switching off,wait then switch on , dash lights normal but rapid clicking from the injector pump, when this clicking stops the van will run normally for a mile or two then stop suddenly. wait a few minutes,starts instantly runs perfectly . No smoke or other symptoms. Could the fuel cut off solenioid be intermittently faulty? Got home in 2 mile stages, removed & drained the fuel filter via the drain tap, few specks of dirt nothing much ,no water in fuel sample,checked the electrical plugs on the pump, all seemed ok. Parked in the drive, the engine starts instantly, runs 10 minutes then cuts out. Repeats the above. I had run unusually low on fuel just before the above events. Any help much appreciated. Bc.
