 moonroof and rear roof stopped working
iddyris
Number of posts: 6
Home City: swansea
Registration date: 2010-10-08
PostSubject: moonroof and rear roof stopped working   Fri Oct 08, 2010 5:42 am
recently i went to close the rear roof only to find it would not shut. the control switch led is lit and pressing the up button activates a relay click in the roof liner but pressing down does nothing.the big moon roof also does nothing at all when switched now.one more thing is the warning bleep roof open indicator has stopped.any ideas
simongd
Number of posts: 161
Home City: Knowsley, Liverpool
Model and year: LH100G 1992 2.4 EFi turbo
Registration date: 2010-01-28
PostSubject: Re: moonroof and rear roof stopped working   Fri Oct 08, 2010 5:46 am
Have you checked the fuse?
If there is a relay in the curcuit it could be faulty or a wire has come loose
iddyris
Number of posts: 6
Home City: swansea
PostSubject: Re: moonroof and rear roof stopped working   Fri Oct 08, 2010 5:56 am
i`ve had a look in the main fusebox,not checked the second box yet,but when i press the up funtion on the rear roof i hear the engine speed dip under load.so unless middle roof and down function are seperatly fused plus the warning bleeper,possibly a relay though but where to find it?
simongd
PostSubject: Re: moonroof and rear roof stopped working   Fri Oct 08, 2010 7:13 pm
In my 1992 SC the relay box is behind a black cover under the dash board in the centre. I do actually now remember reading the labels on the inside cover and I am sure it mentions moon roof.
Could be an earth leak I think if the engine speed dips. The motor shouldn't be using that much current.
iddyris
Number of posts: 6
Home City: swansea
PostSubject: Re: moonroof and rear roof stopped working   Sat Oct 09, 2010 2:39 pm
think i need the roof system wiring diagram, i`ve checked every fuse and relay i can find,the clicking from the roof lining is the blue roof control unit.the only response i get from anything is when i press open/up on either the rear roof controls,the roof control unit clicks and theres a slight engine load for a split second.the roof open warning still does not bleep when exiting the car. its acting like there is no motor power available to lower the rear roof or open the moonroof. any wiring knowledge?
mattyj
Number of posts: 118
Home City: Liverpool Sydney
Model and year: 92 Toyota Hi-ace 4x4 Super custom non turbo
Registration date: 2010-08-05
PostSubject: Re: moonroof and rear roof stopped working   Sun Oct 10, 2010 11:00 pm
get a test light on the fuse box
my dash lights went out on my digital dash
cause was a bad link i put on the reverse lights
van could start but couldn't get it out of park
just a 7.5amp fuse for all that
Number of posts: 907
Home City: Highett Australia
Model and year: kzh100 1996
Registration date: 2008-02-28
PostSubject: Re: moonroof and rear roof stopped working   Mon Oct 11, 2010 10:26 pm
have you accidently pushed the roof lock button?
View user profile http://www.ebony2silver.com
iddyris
Number of posts: 6
Home City: swansea
PostSubject: Re: moonroof and rear roof stopped working   Tue Oct 12, 2010 5:14 am
It is acting like the roof lock is on,except for the relay click on pressing the up action for the rear roof,and still no warning bleeper to say the roof is open when you switch off the ignition. I`m thinking its the control unit gone faulty but not sure how to test for this.
iddyris
Number of posts: 6
Home City: swansea
PostSubject: Re: moonroof and rear roof stopped working   Sat Apr 09, 2011 6:18 am
it was the blue multifuntion unit in the roof lining(where the beeping comes from) pcb had a small burn out which i had to bridge with some wire.
Number of posts: 466
Home City: Preston
Registration date: 2008-11-18
PostSubject: Re: moonroof and rear roof stopped working   Sat Apr 09, 2011 10:00 am
Smile
» Roof repairs
» Roof condensation?
» REAR DISK BRAKE SET RM450
» what is 1/4 inch square hole in rear fenders for?
» Still working web flood
