 Warning lights.
milkman
Number of posts : 100
Home City : london
PostSubject: Warning lights.   Tue Nov 23, 2010 6:50 pm
The warning lights for belt and moisture box come on and beep at startup but go off when you blip the pedal. Is this normal or are they actually giving me a warning. I always thought engine warnings come on at any time and stay on if they are actually warning of a problem.
If you want to drain the fuel (deisel) filter is this done from below? To be hnest accessing the filter underneath looks impossible whatever angle you approach it from!
Marko
PostSubject: Re: Warning lights.   Tue Nov 23, 2010 7:42 pm
Just unbolt the housing (2 bolts) the filter is screwed into...easier to deal with in your hand...moisture trap just unscrews under the filter
Warning lights.
» Personalized Profile fields / Warning System
» Warning system?
» How do i have the warning system?
