 Correct Battery to fit 3.0 SC
hathan
Number of posts: 52
Home City: birmingham
Model and year: 1994 Hiace Super Custom
Registration date: 2010-06-12
PostSubject: Correct Battery to fit 3.0 SC   Tue Dec 21, 2010 11:40 am
Hi pips my 3.0 sc came with a RAC battery which the previous owner had purchased from the rac, i been having a problems with the battery keep packing up on me, so i called out the RAC and they checked the Battery and the man said this battery is not the correct one its 200 amp, n ur vehicle needs 700 amp....Does anyone no the right ampiegbe i need for my SC....AND ALSO MY ALTERNATOR IS FINE NO DRAINAGE TOO...he said due to the cold weater and battery under powerd it cant keep up ....
hathan
Number of posts: 52
PostSubject: Re: Correct Battery to fit 3.0 SC   Tue Dec 21, 2010 11:43 am
And also i was planning on putting a DVD screen in my SC iv heard members having 2 batterys runing in their vans, how and what do i need to do to run 2 batterys....any suggestions thanks....
CHAMRA1
Number of posts: 31
Home City: Melbourne, Australia
Model and year: 98 Supercustom G
Registration date: 2009-04-28
PostSubject: Re: Correct Battery to fit 3.0 SC   Tue Dec 21, 2010 5:19 pm
I think correct application is a 730cca battery , Its 304mm long .
According to the application book .
I'm using a 530 cca maintainance free battery from Acdelco Its 240mm long .
Been troublefree for years .
Number of posts: 466
Home City: Preston
Registration date: 2008-11-18
PostSubject: Re: Correct Battery to fit 3.0 SC   Tue Dec 21, 2010 7:32 pm
Pay particular attention to the terminal type and also orientation...then just buy the largest capacity battery that can fit in the hole.
To run 2 batteries...if you want to use one while the engine is not running do a search / read up on 'split charging system'
hathan
Number of posts: 52
PostSubject: Re: Correct Battery to fit 3.0 SC   Tue Dec 21, 2010 7:51 pm
Thanks chris for your time and help....
Number of posts: 625
Home City: Bristol UK
Registration date: 2008-11-05
PostSubject: Re: Correct Battery to fit 3.0 SC   Wed Dec 22, 2010 9:19 am
I got one last year from ebay battery supplier for £105 Varta Asia for 4X4 import Japanese vehicles - not let me down yet and I have starting problems. Not got a 4X4 either! Next day delivery
simongd
Number of posts: 161
Home City: Knowsley, Liverpool
Model and year: LH100G 1992 2.4 EFi turbo
Registration date: 2010-01-28
PostSubject: Re: Correct Battery to fit 3.0 SC   Wed Dec 22, 2010 11:04 am
Clive I've got starting problems too. Do you know what is causing yours?
Mine may be a too rich fuel mixture. I had the injectors reconditioned and put them in and tryed them. Started okish, but I had to take them out again because they hadn't sealed proberly and the injector tip was coated in carbon deposits. I didn't expect that after only a short time running.
PostSubject: Re: Correct Battery to fit 3.0 SC   Wed Dec 22, 2010 12:27 pm
First I've a cracked head but before that it was allways needed a good cranking over even when hot.
I have the same problem as someone in NZ. It will start over 10 seconds of cranking but have no power, even ticks over at 500 rpm.
Once the K-Seal gives up and I change the head, I'm not ivestigating BUT on the Hilux forum someone did have trouble with the sensors on top of the fuel pump not sending the correct signal to the ECU. I've tried starting with them disconnected both together and one at a time and it made no difference. So perhaps that may also be my problem?
Battery I think is an 083 code?
simongd
PostSubject: Re: Correct Battery to fit 3.0 SC   Thu Dec 23, 2010 10:03 am
Interesting, cause my bus started fine with a cracked head, and now I have a new one I am having problems!
Which are the fuel pump sender wire to the ECU?
hathan
Number of posts: 52
PostSubject: Re: Correct Battery to fit 3.0 SC   Fri Dec 31, 2010 11:07 am
ok pipl need help.........iv put the correct battery in my 3.0 sc iv got a friend who works in the RAC and he checked if my Alternator is charging my battery and im not getting any drainage, and everytings all good, iv checked all my lights and everything, but the issue is my battery is still getting drained out....so does any 1 no what the hell that could be......
Home City: Preston
PostSubject: Re: Correct Battery to fit 3.0 SC   Fri Dec 31, 2010 2:53 pm
Either something is left on or its an electrical short.....maybe moisture build up leading to arcing...mechanical switch....or contact issue in wiring....
Do you have an alarm/immobiliser?
How long from charged before its obvious something has happened?...slow / gutless cranking power etc
dandywarhol
Number of posts: 163
Home City: Edinburgh, Scotland
Model and year: 1995 LH129V 2.8 Superlong semi hi top campervan 4WD with Mitsubishi turbo
Registration date: 2010-01-26
PostSubject: Re: Correct Battery to fit 3.0 SC   Fri Dec 31, 2010 4:49 pm
OK, beg, borrow or steal an ammeter. Disconnect the earth side on the battery and put the ammeter wires between the battery post and the earth terminal.
You might get a slight discharge showing as the radio goes through it's motions, but after settling down, there should be less than 0.05 amps showing allowing for a clock or something causing a slight drain.
Here's some handy tips
http://www.aa1car.com/library/battery_runs_down.htm
KIWI DAVE
Number of posts: 64
Home City: EASTBOURNE
Model and year: SUPER CUSTOM 3.0LT TDI 4WD
1995
Registration date: 2010-01-03
PostSubject: Re: Correct Battery to fit 3.0 SC   Fri Dec 31, 2010 6:47 pm
Very helpfull electrical website Dandy!! I will save that one for future reference Very Happy
Regards Dave
hathan
Number of posts: 52
PostSubject: Re: Correct Battery to fit 3.0 SC   Sat Jan 01, 2011 7:05 pm
Thanks alot pipl for your help.......i have one more question does my 1994 3.0 SC have 2 batteries......is so were is the other one located....
» RWD Drift Test (Yes you read it correct RWD Drift)
» Atv Battery
» Battery
» How To Leisure Battery
» Battery Charger
