 Dual battery
hathan
Number of posts : 52
Home City : birmingham
Model and year : 1994 Hiace Super Custom
Registration date : 2010-06-12
PostSubject: Dual battery   Mon Jan 03, 2011 5:04 pm
do all 3.0 SC like 1994,96 have dual batterys.....if so were does the second one be located...
PostSubject: Re: Dual battery   Mon Jan 03, 2011 5:35 pm
I don't think they do normally.....and don't know where a second one would locate as standard.
I've heard some mention under the drivers seat...but that certainly would'nt work on my 2.8
hathan
PostSubject: Re: Dual battery   Mon Jan 03, 2011 9:07 pm
Thanks for the reply chris....
PostSubject: Re: Dual battery   Mon Jan 03, 2011 11:18 pm
Are you thinking of fitting one?...or wondering if you allready have one?
hathan
PostSubject: Re: Dual battery   Tue Jan 04, 2011 9:58 am
im wondering if i alrdy got 1, the problem l got is my battery whch is behind the passenger seat goes flat while its been driven alternator is fine, but showing 17.5 volts wen i pt a electric meter on, it shud only be 12 volts so my mate is saying ther has to b a 2nd battery or a split charge system. IF ANY IS FAIMLIER WITH THIS PLEASE HELP
PostSubject: Re: Dual battery   Tue Jan 04, 2011 12:32 pm
You should'nt get 17.5 volt even with 2 batteries...13.7v running yes...12.8v or something switched off.
If you had 2 batteries they would be hooked up in parralel ...if the split charge to the leisure battery had somehow gone bizzare the volts would still produce that of 1xbattery....but would run for much longer as the amperage capacity would be around double
Possibly the alternator regulator has gone......(this is replaceable without a full new alternator).....if you are getting 17.5v running the battery will overcharge and warp the plates/destroy the battery.
If you are getting 17.5v with the engine off then yes there's another battery...(which must be wired back to front...ie: wrongly) or your mulimeter is not calibrated / faulty.
If there are 2 batteries then you'd be able to trace the wires from the alternator / main battery to find the 2nd....the 2nd would be hooked up with some fairly chunky wires to avoid voltage drop.
I don't think 2 batteries were standard fittment though as there was never any additional need on the standard supercustom....but camper type vans would likely have a 2nd.
I'm really no expert so I'd run it round to a friendly auto electrician / alternator specialist for comfirmation.
The thing to bear in mind that even with 20xbatteries..wired correctly its still fundamentally a 12v system.....24v you would only find on specialist military / emergency type vehicles and heavy commercials
dandywarhol
Number of posts : 163
PostSubject: Re: Dual battery   Tue Jan 04, 2011 12:38 pm
Sounds like the regulator to me - 17.5v will also start to blow bulbs etc and, as Chris says, fry the battery in no time!
hathan
PostSubject: Re: Dual battery   Tue Jan 04, 2011 5:55 pm
Thanks for your reply chris mate, you put me in the right direction.....
Number of posts : 84
PostSubject: Re: Dual battery   Wed Jan 05, 2011 6:28 am
Don't know if this is relevant, but my '91 Custom, 3L engine, has two 12V batteries in parallel in the same compartment below/behind the passenger seat. It may be possible to put the meter probes in the wrong spot to get a misleading reading, don't know for sure. The camper battery is totally separate, below the rear seat.
dandywarhol
PostSubject: Re: Dual battery   Wed Jan 05, 2011 10:11 am
As long as they're in parallel then the meter should only read battery voltage - around 12.8 off charge, nearer 14 when charging
hathan
PostSubject: Re: Dual battery   Wed Jan 05, 2011 10:33 am
MaIL in your 91 3.0 SC were the batterys located in the same compartment, one under the other or side by side....
PostSubject: Re: Dual battery   Wed Jan 05, 2011 9:33 pm
In the same compartment, side by side Hathan.
@ Dandy - agreed, but without checking mine I was wondering if it was possible for Hathan to place meter probes in such a way that a series reading could be obtained. I don't think it would be though.
Dual battery
» 99th Field Battery RCA
