hi im driving a 1999 manual...it's been stored for 2 years and when I got it back on the road the shifter would sometimes get stuck between neutral to the 1st, and the 1st to the 2nd gear. also does it on the reverse....
the shifter get's jammed and wont allow us to change gears at all,, I have to stop the motor and then it's easy (but dangerous on the hwy)...
it does it warmmed up and cold... there is no leaks on the line(hydrolic clutch) nor on the tranny or the breaks...
I just had a hydro slave replaced as a recommendation from the mechanics but all it changed was 90$less in my wallet,+ a new head gasket that is still leaking(170$ and I cant find how the mechanics got it out, the bolts are still dirty, no scratch)...I also grinded the clutch plate( putting into gear on park brake quickly) as I thought some rust might be in there...
But the problem is still there after all that...thx dumdum mech
and worst, it seems to be heating quickly now and the temp gauge doesn't move...
Im gonna go bleed the clutch once more(I didn't fully do it after the slave got changed)...and I hope I don't have to open the tranny caus honestly I don't realy know what that could be...selenoid maybe??? speed sensors???
does anyone knows what that could be?
Im sick of mechanics who creates more problems to my van... It's only getting worst every time I visit them!!!
It worked fine when I got it out of storage...
Is it time for me to set it on fire???
