 Oil filter and Oil capacity
mjphiace
Number of posts : 43
Model and year : 4WD LWB 2.8 Auto High Top Camper 1994
LH129V-ERPDS
Registration date : 2010-04-07
PostSubject: Oil filter and Oil capacity   Thu Apr 07, 2011 9:21 pm
Anyone know what type of Oil filter I need for a '95 2.8 diesel, and how much oil to put in?
PostSubject: Re: Oil filter and Oil capacity   Fri Apr 08, 2011 7:58 am
Oil filter that fits most ot Toyota Diesel engines - 2 sizes 80 something and 105mm - both fit but as they are the same price 105 is easier to get out. Oil I used 6 litres on both Townace 2ct and Hiace 1KZ engines with a filter change. On both engines the oil takes a long time to filter down from the filler so beware of over filling!
Oil change every 5K KMs or you could end up with gelled oil in the sump! Engines are old and have a lot of blow by, the oil will turn black within hours of replacement.
milkman
Number of posts : 100
Home City : london
PostSubject: Re: Oil filter and Oil capacity   Sat Apr 09, 2011 12:09 pm
Thanks for your posting. What is blow by and what causes oil to gel and why is that bad? I apologise in advance for my sheer lack of knowledge about engines but I have to ask.
Marko
PostSubject: Re: Oil filter and Oil capacity   Sat Apr 09, 2011 12:48 pm
Blow by is exhaust gas blowing down the side of the piston rings into the sump...(worn rings/worn/glazed bores)...the soot colours the oil...I would'nt worry.
Think another big reason the oil gets dirty quick is that there's plenty of gunge in an old engine which does'nt drain away.
Flushing oils used to be common, but don't seem to be a fashion anymore...
Re: old oil...the way I understand it is the lubricating bit (molecules) can be seen as microscopic round balls, that allow surfaces to roll over each other without touching...the balls get flattened/hammered over time...
PostSubject: Re: Oil filter and Oil capacity   Sun Apr 10, 2011 10:29 pm
Old and dirty oil PLUS heat can turn to sludge/gel. It don't flow and therefore don't lubricate and can even block oil ways. When you drain the oil it stays in the sump, si if you refill and 3 litres or less is need to reach the full mark consider having the sump dropped and cleaned out.
Adam
Number of posts : 20
Home City : London
Model and year : 1994 2.8 LWB Mid-top Camper
Registration date : 2010-03-17
PostSubject: Re: Oil filter and Oil capacity   Mon May 09, 2011 9:13 pm
Hi Mate
I have the same engine as you and have been doing my own oil changes for the last couple of years, have a read of this Servicing Info That got me on the right track. I buy the filters from Japarts They are very helpful and not too expensive. 5 Litres of oil is required, I use 10w40
Good Luck
Adam
» Blood Red DMD filter added to Sopranos....
» Diminished Earning Capacity (DEC)
» TPI Medical Questionnaire: Employment Capacity VAC671e
» better forumotion spam filter
