 Super Custom Radio change
Clockman
Number of posts : 38
Registration date : 2007-09-13
PostSubject: Super Custom Radio change   Tue Sep 18, 2007 7:33 pm
Hello all, Any tips re changing a radio on a SC 1994.I have no problems removing dash etc. Can only DIN fitting be used ,are there any hidden amps anywhere. Any recommendations on which radio welcome. Thanks.
Number of posts : 1116
PostSubject: Re: Super Custom Radio change   Tue Sep 18, 2007 11:09 pm
Helllooo Clockman.
I swapped the unit on my '95 SC and just tested the connectors with a m/meterand a speaker to check front / back and left / right.
As regards which type I have a kenwood with a input so I can use an mp3 player (about £60)
If I get chance on the weekend I will make a note of the connector wiring if it helps.
GOOD LUCK
Grisly
Registration date : 2007-09-08
PostSubject: Re: Super Custom Radio change   Wed Sep 19, 2007 7:07 pm
I am currently struggling with working out how to fit my car stereo too!
1) First of all I had no brackets - but since got those and part numbers.
2) Today I got the stereo itself.
3) I can't figure out how to get the dash off, just above the key.
The whole thing wants to come off, but something there jams it.
4) Once I get the dash off I can work out what type of frame to use.
I'll continue with a search here and hope I find better instructions.
5) My wagon has 5 white connectors and several loose wires in the
radio compartment. 4 of them are a combination of male/female
Toyota fittings, and once now connected together they would
seem to feed signals (after disappearing off out of sight) into a
smaller female block with 1 row of 2 x 3, and row 1 7 connectors.
I do not know if this is the final block, or some mutant accessory!
Any advice or wiring of the loom (and a photo ideally) would be great!
Cheers, and thanks,
Richard.
Clockman
PostSubject: Re: Super Custom Radio change   Wed Sep 19, 2007 7:58 pm
HI again, Thanks for your replies.Having had a quick look at the wiring I considered the possibility of a second amp hidden somewhere. No decision on the new unit yet. I entered Halfords today just for a look and asked the lad for some info. What a laugh, He had never heard of a Hiace SC,nor the DIN standard for fitments,he actually thought that I was referring to the volume of sound produced,assuming that a double DIN unit made more noise than a single. Trying to explain the Deutsches Institut für Normung standards system met with a blank stare.He obviously thought I was bonkers. However an amazing selection of units are available. It's about time to scrap the faithfull Bluespot Koln circa 1966 which has served me well.
On Grisly's dash problem the following may help. Remove the lower panel under the steering column, remove the lower dash screws, remove the screw above the speedo. rotate the Rh centre top air vent upwards & remove the hidden screw, the dash panel pops off spring clips,unplug the switch wires (they are all different and cannot be mixed up )a little wiggling gets the panel out past the wheel. While the panel is off pop out the switches & polish up the plastic.Alternativley cover it in pink fur or to your own taste. The tightly stretched skin of an endangered species can look rather fetching.
PS what are blue teeth and why should a radio need one ?
Clockman
PostSubject: Re: Super Custom Radio change   Wed Sep 19, 2007 8:00 pm
Grisly
PostSubject: Re: Super Custom Radio change   Sun Oct 14, 2007 9:07 pm
Hello,
I recently got partial details about the Hiace SC radio variations.
I will grab a photo. I have diagrams of 2 variations, one with amp,
one without. The one with amp seems to be used with a mini-disk.
I'll try to post tomorrow the image.
I'd still appreciate any details about the wiring, that isn't detailed.
Richard.
PostSubject: Re: Super Custom Radio change   Sun Sep 14, 2008 12:21 pm
This is a bit late but the amp on a 94 SC is up behind the glove boxup near the windscreen.Hell of a job getting at it. Just had a Kenwood 2din fitted and the fitter still hasn't got the rear speakers working ....took him all day to get this far.Reckon he wont do another SC Smile
jimsmim
Number of posts : 188
Home City : paisley
PostSubject: Re: Super Custom Radio change   Sun Sep 14, 2008 2:49 pm
you can purchase a plug that will plug into the back of your euro spec tranni and connect with the jap spec loom ...there are two types one for a normal single cd player and an amplifier type for the vans that have the double system..... bout £10 for the normal 1 and £20 for the amplifier type.... I got one from a car audio specalist up the road but they may be available from ebay....
PostSubject: Re: Super Custom Radio change   Mon Sep 15, 2008 9:13 pm
Now you tell me Smile Smile If I see him again I will tell him. Thanks mate
brizbarnhart
Home City : Portland, OR USA
Registration date : 2017-12-04
PostSubject: Re: Super Custom Radio change   Mon Dec 04, 2017 6:58 pm
Grisly wrote:
Hello,
Richard.
Did you ever figure out what you need for the Hiace radio swap? I have an imported from Japan 1992 Toyota Hiace Super Custom. I already snipped the original wiring harness out, but can't figure out what color wires mean what. I have a Panasonic head unit that I bought useds off of craigslist. The colors of my wires left to right are:
Top row: black w/ silver dots / blue w/ silver dots / brown w/ silver dots / blue with red stripe / green w/ white strip / pink w/ blue stripe
Next row: green w/ silver dots / yellow with silver dots / red w/ silver dots / white w/ silver dots / gray with black stripe / black w/ white stripe
its only one connector (loom), not two like some toyotas. Any help would be great.
Number of posts : 183
PostSubject: Re: Super Custom Radio change   Mon Dec 04, 2017 9:19 pm
I fitted a double din cd/tape/radio and the factory wiring is bonkers to work out so I put my own in, found ignition live, battery, earth, lights on and took feed from speakers back to unit, works all fine fir me now
Number of posts : 529
PostSubject: Re: Super Custom Radio change   Tue Dec 05, 2017 4:19 pm
A cheap eBay Toyota Yaris adapter fits to go from Toyota to DIN.
I would not guarantee van wiring colours, I've not known them to be consistent.
The wiring is conventional - i.e. two wires to each speaker, lights on, ground, power and switched power so a multimeter should let you identify them all. If you identify the power and switched power first, then you can safely get the speaker wires with the lowest ohms scale as the speaker should quietly click as you measure it.
» Change Domain Name
» Super QUICK help on forum domain change
» Michael Shrimpton Interview- Bristol Community Radio
» CSS codes for customizing phpBB3 forums
