 rear bench seat
simongd
Number of posts : 176
PostSubject: rear bench seat   Fri May 06, 2011 3:54 pm
Can the rear bench seat be removed from the vechile?
PostSubject: Re: rear bench seat   Fri May 06, 2011 10:43 pm
yes it can mine has been removed for a wheelchair hoist.
PostSubject: Re: rear bench seat   Mon May 09, 2011 1:32 am
They are bloody heavy mate. Not something you do every day.
simongd
PostSubject: Re: rear bench seat   Mon May 09, 2011 5:14 pm
I am buying a motorbike and might need to put it in the back.
How is it done? Undo some bolts I suppose.
PostSubject: Re: rear bench seat   Fri May 27, 2011 3:23 pm
can't help sorry mine was already removed
ricardo
Number of posts : 48
PostSubject: Re: rear bench seat   Fri May 27, 2011 11:55 pm
Yep they just unbolt. Some times you need to remove plastic coverings to get at the bolts. Youl see, it easy!
PostSubject: Re: rear bench seat   Mon May 30, 2011 11:26 am
Yes just unbolt, disengage the slider release cable and unbolt, leave the slider brackets in the slider as these are useful as strapping points to tie down whatever beast you put in. I had a cruiser in the back of mine needed to turn the middle row through 90 degrees then there was loads of room.
simongd
PostSubject: Re: rear bench seat   Tue May 31, 2011 5:55 pm
Thanks guys
I took the easy option and found a man with a van, but it may be useful info for the future... you never know.
btw. its just a Kawasaki er5
simongd
PostSubject: Re: rear bench seat   Mon Aug 08, 2011 12:42 pm
Its a piece of cake after the first time doing it once I figured it out it only takes 10 minutes.
rear bench seat
