 A little help needed!
x11stu
Number of posts : 17
Home City : Warrington
Model and year : 1992 hiace
Registration date : 2011-05-19
PostSubject: A little help needed!   Thu May 26, 2011 12:44 pm
Am going away for the first time this weekend just need a bit of advice regarding driving. The overdrive putton has been depressed in since i bought it, do i keep it in or let it out? also a small red button near the gear lever wht is it? as you can guess i have not been given the owners manual yet.
Stu
PostSubject: Re: A little help needed!   Thu May 26, 2011 2:09 pm
O/D most the time. Unless you are towing you would probably only want to turn O/D off for engine braking on steep declines, it is just like dropping down a gear. In normal use it is like an economy top gear.
Red button releases the gear shift without the ign key or brake pedal being used, mainly for use when pushing the bus about with no battery power i.e. in the garage. You will use it at some stage but otherwise forget about it.
Have a look at www.teoc.ws meets section, you or indeed anybody are welcome to attend most of the meets (some are TEOC only, some needed to be prebooked), and join a group of like minded vehicle owners and maybe a pint or two at beer o'clock.
x11stu
PostSubject: Re: A little help needed!   Thu May 26, 2011 4:28 pm
Thankyou so much for your response and time. i sort of thought that was the case but needed it confirming.
Thanks again.
Stu
PostSubject: Re: A little help needed!   Fri May 27, 2011 3:18 pm
you are able to get one from
www.jpnz.com.nz
if you don't get one Very Happy
» Milk needed in Indiana
» Milk needed for adopted baby
» milk needed for upcoming baby
» Rank Bars Tutorial Photoshop-Needed
» DONOR DROP OFF CENTERS FOR MY SON ZIGGY (will pick up if needed) CLICK AND SEE ARE STORY!
