 tyre pressure
gillypoof
Number of posts : 11
Home City : brighton
Model and year : toyota hiace camper 2.8 4wd diesel auto
1994
Registration date : 2010-09-04
PostSubject: tyre pressure   Sat Jul 16, 2011 12:43 am
what presures on my tyres???????
i.ve got a 2.8 diesel hiace camper.and a jap handbook,with pictures.nice but usless
View user profile http://greensquat@ntlworld.com
PostSubject: Re: tyre pressure   Sat Jul 16, 2011 4:30 am
i run mine on 40psi
WERX
Number of posts : 475
Home City : Sydney
PostSubject: Re: tyre pressure   Sun Jul 17, 2011 8:29 am
Am running 18" mags on 38psi
Number of posts : 91
PostSubject: Re: tyre pressure   Sun Jul 17, 2011 9:12 am
Isn't there a tyre specification label on the driver's door frame? It seems that there are different models. Mine runs light truck tyres with the label showing 50psi front and 65 rear.
CustardCrazy
Number of posts : 65
PostSubject: Re: tyre pressure   Mon Jul 18, 2011 8:41 am
It all depends on the tyres, Light truck tyres are designed for higher pressures as MalL has said. I have 215/70/15 Yokahama AT tyres which sit just right at 45 psi front and rear. You can test the contact patch by driving slowly driving across a wet concrete patch onto a dry section and check you are getting full width pattern. I would start at max pressure listed on the sidewall and go downwards. The pressure listed on my placard is 35psi but at that my sidewalls are running on the ground. This might have been ok for the original tyres. Later tyres I have found require more pressure as the sidewall stiffness is less than used to be manufactured. Different tyres vary greatly in the construction and therefore pressure required. Slightly overinflated tyres will greatly outperform slightly underinflated tyres in braking and handling. They will also run cooler.
Cheers, Dave
WERX
Home City : Sydney
PostSubject: Re: tyre pressure   Mon Jul 18, 2011 8:49 am
I probably need to look at my pressuires as i lost it completely the other day, uphill, on a bend in the wet. some rather surprised passengers!!! although i could start a Sideways in Sydney movie - any helpers?
PostSubject: Re: tyre pressure   Mon Jul 18, 2011 8:54 am
My Prado is placarded at somewhere around 30psi I think but the local dealer recommended increasing to 40. It certainly improved things, especially in the wet.
I don't know for sure but guess that 65psi for the rear of my Hiace would be right for a loaded cargo van but might be overdoing it for a lighter (?) campervan.
Diverting slightly from the topic, but I have had problems with all four tyres loosing pressure, to the extent of at least 10psi a week. I took the van into Beaurepairs today and they found that the cause was the knock-on type balance weights. They've replaced them with a stick-on type.
lincshiace
Number of posts : 4
Home City : Lincoln, UK
Model and year : 1998
KZH138 Hiace wagon
1kz-te
4wd auto
Registration date : 2011-08-09
PostSubject: Re: tyre pressure   Wed Aug 10, 2011 7:10 am
My recently acquired Hiace is missing the tyre pressure label. I've got the english translation of the owner's manual but unfortunately it does not provide any info on what the correct tyre pressures are.
The van is currently on Bridgestone RS600 light truck tyres 195/80 R15. The front tyres are at 40 psi and the rear tyres 45. Are these ok ?
Django-Wildheart
Number of posts : 29
Home City : Penarth
Registration date : 2012-11-19
PostSubject: Re: tyre pressure   Tue Nov 27, 2012 10:09 pm
my very reliable tyre people looked at the van knowingly the other day and said "50 all round - they could go to 60 but why would you." These are very chunky tyres it must be said . . .
Scrotes
Number of posts : 24
Home City : Wellington. NZ.
Model and year : 1994 SC 3.0 TD 4WD. -most useful vehicle I've ever owned. Should have bought one years ago!
Registration date : 2010-09-11
PostSubject: Re: tyre pressure   Wed Nov 28, 2012 8:15 am
I have 235/60 all terrains on 16" alloys which I run at 45 front and rear. For me the trick is to get the tyres wearing evenly across the width of the tyre.
Too low and you'll wear out the shoulders pretty quick, too high and you'll wear down the centre (-this sounds like a porridge story! Smile ).
45 gives a good ride with even wear across the width of the tyre.
tyre pressure
