 dashboard removal
milkman
Number of posts : 100
Home City : london
PostSubject: dashboard removal   Sat Jul 23, 2011 7:09 pm
Having read Fiona's post I removed some screws, the ones I've found so far are shown by pointers in image below.
However try as I might I can't get the thing off. The top is loose definately but the bottom seems very solid.
Any ideas. The moment I get the hang of this I'll post a guide I promise!
IMG_0038-Edit.jpg by markuspalarkus, on Flickr
PostSubject: Re: dashboard removal   Sun Jul 24, 2011 2:40 am
you have removed all the screws needed to remove the dash. Jiggle the fuel cap lever so that it is behind the dash lower plate then remove the plate by pulling upwards toward the steering wheel.
The black dash cover should then be loose enough to pull (carefully) upwards from the bottom towards the wheel.
when it is free disconnect all the wires to the switches and clock,you should then be able to get at the radio and all the rest of the instruments.
cheers
dave
PostSubject: Re: dashboard removal   Sun Jul 24, 2011 2:41 am
forgot to add lower the steering wheel Embarassed
dashboard removal
» Cipriano Case: Psychic Prosecution Lawyer requests removal of the President Judge Henrique Pav„o
» So, There IS such a thing as "TREE LAWS!" (on Public Parkways!)
» Ad removal?
» Removal of adf.ly
» Forumotion Footer Copyright Links Removal
