| | Help - Excessive fuel consumption in a 2.8 super custom | |
| Author | Message |
moogdrew
Number of posts: 58 Home City: Melksham Model and year: 1993 Hiace Super Custom Limited 2.8D (LH107) Registration date: 2007-02-17
 | Subject: Help - Excessive fuel consumption in a 2.8 super custom Mon Oct 15, 2007 8:39 am | |
| My 2.8l flat diesel super custom ltd is returning a consistant 21 miles to the gallon no matter how i drive it!
Can anyone tell me what it should be doing ?
Also any ideas why its so bad? - it has new air, oil and fuel filters, new oil, most of the gearbox oil changed, has had regular doses of injector cleaner, it does not smoke and there are no signs or smells of a leak.
Can any one tell me what engine revs it should be on at 60mph (not kph) in 4th gear mines on just under 3000rpm sounds a little high to me ? |
Number of posts: 148 Age: 60 Home City: Lincoln England Model and year: 1993 Hiace Campervan 4WD 2779cc Diesel Auto Transmission Registration date: 2007-07-17
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Mon Oct 15, 2007 1:59 pm | |
| I have a 2.8 Super Custom Camper and get approx 20-25 mpg - these buses are plodders, no turbo and no guts!! Seriously, I went down the extensive economy route and came up with the same results. My auto box revs quite high but I am past caring, its comfortable, reliable and I love it!!It cruises at 60mph all day on waste Veggie Oil- the best way to save money- 50 pence per litre duty paid from a local supplier. Don't be tempted to play with the Injector Pump, I did and it cost me a lot of pennies to re-calibrate it . I tweaked and got loads of power along with a smokescreen a Frigate would of been proud of!!But the MOT Tester was not impressed!! |
moogdrew
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Tue Oct 16, 2007 3:39 pm | |
| Cheers for that - I know what you mean about the comfort making it all worth it - i'd put up with 15 mpg for this much comfort. At least i know theres nothing wrong with it now - i was just about to spend £240 on getting the injectors revamped cos everyone was convinced it should do close to 30 mpg! Thanks again |
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Tue Oct 16, 2007 4:57 pm | |
| Got my injectors refurbished in Lincoln for £75 last year
New springs, pintles & seals etc. And Pressure tested.
Try Specialist Injection Services Exchange Road Doddington Road Lincoln for a quote Tel 01522 691182 A good bunch of lads! |
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Tue Oct 16, 2007 5:03 pm | |
| They also refurbished and calibrated my Injection pump for £200 after an idiot with a screwdriver, 8mm spanner etc played with it to squeeze a bit more power out of the bus. Got the power at the cost of reduced mpg and a smokescreen that was like stubble burning.That'll teach me!! |
moogdrew
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Thu Oct 18, 2007 2:11 pm | |
| Thats alot better than the prices ive been getting - might have to see if they will do them by post (i live down near Bath) - its almost worth getting them all done as a service item for that price Cheers for that |
Admin Admin
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Thu Oct 18, 2007 7:39 pm | |
| There is a toyota specialist at Warmley, Bristol.. I dont know if they have worked on the Hiace but might be worth looking up.. |
moogdrew
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Mon Oct 22, 2007 4:36 pm | |
| Cheers - i'll look them up. I Have been wondering latelly if the ice tyres that it was imported could be causing my bad mpg - had a puncture the other day and put the spare on (standard road tyre) - just that one normal tyre made such a difference to the rolling resistance that i'm gonna change a pair and see what happens. |
jimsmim
Number of posts: 188 Age: 44 Home City: paisley Model and year: VW TRANSPORTER T5 LWB poptop camper Registration date: 2007-11-17
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Sun Nov 18, 2007 1:02 pm | |
| :Hi.... just purchased a 2.8 super custom pop top camper and I'm a bit disheartend to discover it only returns 20-25 to the gallon as I was led to believe high 20s in town and 30+ out of town were easily acheivable... I was initially going to purchase the 3ltr hiace but as I was told the expected mpg of this vehicle would be low 20s, I went for the 2.8 non turbo ... to discover the 2.8 is as bad on fuel as the 3ltr yet a lot less powerfull is a downer .... can any one clarify this for me .... cheers |
alltorque
Number of posts: 13 Registration date: 2007-10-23
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Tue Nov 20, 2007 10:18 am | |
| My take on it is that people quote the km per gallon rather than mpg. Mine is definitely no better than 22mpg.
On a tank of 50l (£50!!) it covered 450km, which equates to about 21.3mpg. And that was with alot of motorway miles, cruising at 60mph.
You don't drive these for their frugality! Still totally in love with the beast though :-) |
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Tue Nov 20, 2007 7:49 pm | |
| Your figures alltorqe are virtually the same as my 2.8 itr Campervan. I regularly drive from Lincoln to March in Cambs, and on the Fen Roads I get 20mpg - 450km for 50ltr is about my limit. Being an engineer, I tried all avenues to squeeze a few more miles out of the bus but to no avail!
Veggie Oil, various timing options, weight reduction, larger wheels and tyres, frugal driving, various diesel additives, injectors refurbished, injector pump recalibrated, regular service,electric fan replacing the viscous fan.etc etc etc
Trust me if there was a way to get more out of the old gal I would try it, but now I just drive and enjoy!! |
jimsmim
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Fri Nov 23, 2007 2:12 pm | |
| And here was me thinking my bongo was sh*t on fuel .... must admit if I had known fuel consuption was so bad , I would have went for the 3ltr turbo as I find the 2.8 gutless...oh well ... seriously more room than the cramped bongo...guess you cant have everything...  |
Admin Admin
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Fri Nov 23, 2007 6:20 pm | |
| Also dont forget...Our forum isnt that green  (I mean the colour and not eco friendly)
Clockman
Number of posts: 38 Registration date: 2007-09-13
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Sun Nov 25, 2007 6:28 pm | |
| Mine averages 21 mpg regardless of driving style.(3lt turbo) My 2.4 's do 30 easily but are noticably lighter in weight apart from the obvious other differences.My friend has a fancy VW which does about 30 + but costs him £270 a month in HP.Our buses are petty cash stuff by comparison and considering the reliability are still cheap motoring,fuel being the only real expenditure. Both my 2.4's have done over 120k miles with nothing other than the usual tyres, pads etc, these hi ace vans must be one of the most cost effective vehicles on the road.My oldest 2.4 cost £1800 six years ago and has just gone for £1100.Buyers were fighting over it. Who cares about a few gallons of diesel. |
zoochy
Number of posts: 148 Home City: Tropical Canada Model and year: LH107G 1991 Registration date: 2007-01-21
 | Subject: Re: Help - Excessive fuel consumption in a 2.8 super custom Sun Nov 25, 2007 7:30 pm | |
| Thanks for the props Clockman. I wish I would have that testament to show my friend 2 years ago. I imported I Hiace and he imported a Townace. He has had to spend about $8,000 CDN repairing the damn thing and I have had to spend $0.
If you want to be more green, start by burning 1/3 waste vegetable oil. You can do this w/o any major modifications and start saving immediately. |
