 Leaky diesel pump
maztez
Number of posts : 89
Home City : Gold Coast Qld
PostSubject: Leaky diesel pump   Sat Oct 08, 2011 5:07 am
Can anyone give me an indication as to the costs involved in having a fuel pump that is leaking, repaired ..I am getting allsorts of scary predictions and thought I should ask the experts ..Thanks in anticipation
cheers Tezza
PostSubject: Re: Leaky diesel pump   Mon Oct 10, 2011 7:42 am
Depends where it is leaking from, there are several bolt on bits that are sealed by a neoprene O ring, less than 1$AUS each. Or from the injector pipes maybe just need a tweak up?
If the pump needs to come off to fix it still can be done by the home mechanic for peanuts.
The only real big cost is between the low and high pressure parts of the pump, not beyond a home mechanic but many things could go wrong.
maztez
PostSubject: Re: Leaky diesel pump   Mon Oct 10, 2011 8:09 am
Thanks for your reply Clive , I have not long had a call from Toyota advising that the leak is from a couple of seals at the top of the pump and it should be ready in the morning ...bloody good news after nearly 5 weeks without our van ...
cheers Tezza
maztez
PostSubject: Re: Leaky diesel pump   Tue Oct 11, 2011 5:52 am
Just picked up the SC ..had to sit down when paying the bill tho ...$2503 ...renewed bearings ,seal,flange ,oil,element sub assembly ,injector service,repair fuel pump leak ....air filter (ordered Japan )...not happy ...have only done 5728 k since we bought it ...
cheers Tezza
PostSubject: Re: Leaky diesel pump   Tue Oct 11, 2011 8:12 am
Yes a bit over the top but now you will have trouble free motoring for many years to come.
PostSubject: Re: Leaky diesel pump   Tue Oct 11, 2011 8:40 pm
Hinterland or Grand mate?( Gold Coast dealers) Bloody hell they didn't miss. The air filter is the same as ordinary Ace.Though if they serviced the pump it's pretty good. Reco pump $1600 odd and injectors $500 http://www.dencodiesel.com/store/comersus_viewItem.asp?page=store&idProduct=296&idCategory=109
Hope all is well for you now mate. I'm in today to have gearbox cheecked out and serviced
maztez
PostSubject: Re: Leaky diesel pump   Thu Nov 17, 2011 9:30 am
The ongoing saga of the leaky pump ..Toyota fixed the leak problem , had the van back for couple weeks and now the pump has died .. It is stopping and starting so I had it towed to Toyota ..what a bunch of no hopers ..didnt know what the problem is but could investigate for around $120 ph ..In frustration I went to a mechanic nearby who put his finger straight on it ..the electrics in the pump are rs so they are preparing a quote for the warranty mob but advised me that it was around 7 hours to remove and replace same pump.pretty much over this whole saga , and will be without a van for another week ..
cheers Tezza
maztez
PostSubject: Re: Leaky diesel pump   Mon Nov 21, 2011 7:54 am
Got some news today re the pump , and has been traced to a fault in the computer , working intermitantly . Should have the van back in a couple of days after this has been fixed and not by Toyota ..
This time the costs are a bit better and not a toyota ripoff ...
I will post further info when it comes to hand ..
cheers Tezza
tamarack
Number of posts : 101
Home City : Vancouver
PostSubject: Re: Leaky diesel pump   Sat Mar 24, 2012 8:40 pm
just replaced governor cover gasket on the fuel injection pump and now there is no fuel to the injectors. I'm priming the system with the pump on top of the fuel filter but not starting.
CHAMRA1
Number of posts : 39
Model and year : 98 Supercustom G
Registration date : 2009-04-28
PostSubject: Re: Leaky diesel pump   Sat Mar 24, 2012 9:36 pm
Sometimes the hand pump doesn't work when completly empty .
Try using compressed air .
Get a rag and a blow gun and blow in the filler neck , Use the rag to seal the hole .
Get someone else to prime the pump while you do this .
When you fill good resistance with the hand pump you know its working and it should start.
Leaky diesel pump
» Free Harmony Hand Pump
» What causes leaky gut syndrome and how to heal the intestines
» Fresh water pump issue..
» Milk needed in Indiana
» Looking to donate Dairy/Soy free milk in Nashville
