 Central locking
Clockman
Number of posts: 38
Registration date: 2007-09-13
PostSubject: Central locking   Thu Oct 18, 2007 5:00 pm
Anyone have details on the central locking configuration. Is the trigger Neg ,Pos or both. New stereo and immobiliser fitted but I would like to interface the locking with the immobiliser which has this facility built in. Wiring colours and placement of the CL control module would be helpfull if anyone has these. I have tried all over for a wiring diagram without success so far. Just a note on dealers, my local dealer is most helpfull and has put my bus on the Toyota computer so that any enquiry just needs the Reg no. to bring up all the info. Virtually any parts are available in a few days from the Toyota centre in Belgium. It may be worth starting a page on Import friendly dealers here for members to note when away.
Spud_Gun
Number of posts: 200
Home City: Taunton, Somerset UK
Registration date: 2007-02-06
PostSubject: Re: Central locking   Wed Oct 24, 2007 6:15 pm
Had to fit a slave central locking motor on mine as the lock in the cab door doesn't have a drive motor, only a signal sender to comand the remaining central lock motors.
The factory unit worked from a pos/neg signal via a control unit when I was playing with mine, so went on the good old bay and got a central lock motor to contol the driver's door lock, which threw the remaining locks.
If your alarm/imm is good, it will indicate how to connect single drive motor. Smile
Clockman
Number of posts: 38
PostSubject: Re: Central locking   Thu Oct 25, 2007 5:37 pm
HI, Spud gun, Thanks for the reply. My bus has central locking from the key, thus probably has a motor in the cab door. I am trying to interface the alarm to reduce the button pushing. I cannot thiink why wiring info is not available, this would solve the problem .
Spud_Gun
PostSubject: Re: Central locking   Sat Nov 17, 2007 11:52 am
When you say it is done by the key, do you mean you use the key in either door and will unlock all, or do you have a key with remote buttons on it? May have the answer if I can establish how the system works. Smile
malcolmcook
Number of posts: 1
Registration date: 2007-11-22
PostSubject: Re: Central locking   Fri Nov 23, 2007 1:39 pm
My wife has a Toyota Hiace 2.4D GSLWB 1998
Having trouble starting it in the mornings, she has taken it to a diesel specialist and a electrical specialist neither can work out the problem.
I see you deal with electric faults I'd appreciate any comments.
Many thanks
Malcolm Cook[/b]
jimsmim
Number of posts: 188
Home City: paisley
Model and year: VW TRANSPORTER T5 LWB poptop camper
Registration date: 2007-11-17
PostSubject: Re: Central locking   Fri Nov 23, 2007 5:21 pm
have you tried replacing usual suspects like the glowplugs ..air filter ...? are you getting power to the glow plugs
Spud_Gun
PostSubject: Re: Central locking   Fri Nov 23, 2007 6:56 pm
Hi Malcolm,
Worth knowing how long it takes for the glow plug light to go out and what work that you have had done (what parts have been replaced to date).
All being well, should get an idea of where to look next.
Clockman
Number of posts: 38
PostSubject: Re: Central locking   Sun Nov 25, 2007 6:07 pm
HI, Spud. Have been away, My bus locks from a button on the key which locks all doors, however the other doors do not operate each other. It also has the speed operated locking which does not unlock on slowing down. Not too keen on this last feature however.Hope this clarifies things
Spud_Gun
PostSubject: Re: Central locking   Wed Nov 28, 2007 10:04 pm
Will get onto Meta and find out if they have a Top/Mid Pulse wiring diagram for this bus (for those that do not know, this type of alarm can be controlled by the original central lock key). Leave it with me.
Central locking
» Rick's 60g Planted South/Central American Cichlid Tank
» Central locking
» Wanted - Wiring diagram for central locking/electric curtain
» do swifts have central locking?
» Central Locking : Front Door Locks
