 Auto gearchange all over the place!
Philip D
Registration date : 2011-12-07
PostSubject: Auto gearchange all over the place!   Wed Dec 07, 2011 4:29 am
I have had a 1990 diesel with automatic gearbox for 3 years now and have had the car serviced professionally regularly. However, it seems to me to be getting more sluggish and the gearchange to the automatic gearbox is either really sluggish to change as you get faster and then at higher highway speeds when cruising it starts to "hunt" for a lower gear. I am sure the oil level is OK and I had the oil entirely changed not long ago as well. I see there are quite a few people complaining of frustrating auto gearboxes so maybee there is some sort of factory fault with this? Otherwise the car is great!
PostSubject: Re: Auto gearchange all over the place!   Wed Dec 07, 2011 5:41 am
Have you had the box serviced by a auto box professional it may need the bands adjusted
PostSubject: Re: Auto gearchange all over the place!   Wed Dec 07, 2011 12:21 pm
Its possible the kickdown cable may need adjusting slightly....note position of ferrule on cable and only adjust within 3mm...its sensitive.
When maladusted the gearchanges literally go bananas.
Also check the atm oil...does it smell burnt or is it very dirty?....this would indicate wear...a flush and replace can rejuvinate things sometimes...
Dangarus
Number of posts : 12
Home City : Manchester
Registration date : 2011-07-04
PostSubject: Re: Auto gearchange all over the place!   Thu Jan 05, 2012 2:16 pm
Philip, Did you manage to fix this problem? I have had what sounds like the same issue on my 1993 SC and havent yet got around to fixing it....
dandywarhol
Number of posts : 163
PostSubject: Re: Auto gearchange all over the place!   Mon Jan 23, 2012 9:20 am
Maybe you're looking at the wrong area for your problem. You said the gearbox oil is fresh, so presumably any burning of the clutches/bands would have been recognised at the oil change..................
If the engine is not in a good state of tune, then you will be applying more throttle to compensate for the lack of power. Using more throttle "tells" the autobox to use different change up/kickdown points.
Possible problem areas?
Engine tune, assuming it's diesel, worn injectors/pump/fuel filters/air filters choked/tight valve clearances/low cylinder compression...............etc.
What I'm getting at is, make sure the engine's in tip top shape and the 'box will follow on - it's very throttle/load dependant.
Oh, also make sure your brakes aren't binding!
Good luck Smile
» Chatbox auto Login
» Auto-Subscribe to groups
» auto topics !
» Auto-pruning into Auto-Locking
» Auto-pruning
