 Air Con Recharge
Viceroylodge
Number of posts : 8
Home City : Brighton
Model and year : Toyota Hiace Super Custom 2.4 1993
Registration date : 2007-09-04
PostSubject: Air Con Recharge   Thu Dec 29, 2011 4:21 pm
I wnet to Kwiik Fit to take advantage of an offer for a cheap air con recharge. The guys in there couldn't find where to recharge the vehicle and weren't sure what gas to use (my manual is all in Japanese!).
Can anyone help?
Thanks,
simongd
Number of posts : 176
PostSubject: Re: Air Con Recharge   Mon Jan 02, 2012 6:06 pm
look under the front of the vehicle on passenger side. you'll see the two valves with plastic covers. its them.
PostSubject: Re: Air Con Recharge   Tue Jan 03, 2012 8:49 am
Lift up engine hatch if you have a a yellow sticket that is what you have.
93 is when Toyota changed from R12.
If yours is still R12 Kwikfit may not touch it but DON'T get the vlaves converted as you can still charge the system with a replacement gas through them. You may have to shop around and pay a bit more to find someone who ,can do this.
PostSubject: Re: Air Con Recharge   Tue Jan 03, 2012 10:15 pm
The r12 (if in) needs sucking out 1st...just use a mobile air con guy...1400gm of 416a gas pumped in nearly 8 years ago...since then I just top up with a kit from Halfords
Air Con Recharge
