 Wiring Diagrams Plus for Hiace Vans
Go to page : Previous  1, 2
Dione
Home City : Mandeville
Registration date : 2016-10-23
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Thu Oct 27, 2016 6:39 am
The 1jz is quite long... After some bruised and a scraped hands and a engine hoist I managed to get it to fit, had to modify the mounts on the cross member as the 1j is more of a vertical orientation. The radiator has some clearance in front, as I am planning to use the 1j clutch fan. The gearbox is the Hiace own 5 speed box I had a machinist cut the bell-housing and welded the 1j automatic transmission bell-hosing end on the Hiace gearbox. Hiace fly wheel had some slight weight reduction so to make up for some of the reduced torque and machining to bolt holes so will be using the Hiace clutch and pressure plate.
I was planing to go the L series diesel as I got the 2L in the ace long story short it obviously overheated and the block cracked it was after I put it together that was noticed. 2RZ are expensive in Jamaica as the are commercial gas engines and all my modification so far still couldn't not cover a second hand 2rz not to mention anything about the 3rz. Never the less they are quite reliable engines though.
I will post some pictures( WARNING IT IS SOMEWHAT GRAPHIC CONTENT ) I haven't gotten around cleaning up the Hiace as yet. BTW does anyone have the wiring diagram for the ace my electric are a mess. I need to find what relays do what the two relay box cover are missing I have been trying to sort it all out but its quite time consuming and this being a SC there are plenty wires in there. scratch scratch
Number of posts : 648
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Thu Oct 27, 2016 9:06 am
If you're going to share pictures, just do it in a new topic that you can create. For example in "Show us yours" category. This is already going way offtopic.
When it comes to the wiring diagrams, I discovered there are some relevant wiring diagrams in a manual that I downloaded. But I don't have the full link anymore. It also supposed to have some kind of index, but I don't know how it works. But when picking random PDFs in the folders that I have, I notice that some are relevant. But it is impossible to search in, so you just have to go one by one. However, better than nothing. There are also these CD's for sale on Ebay:
http://www.ebay.nl/itm/TOYOTA-HIACE-1989-2004-RZH-LH-Series-Workshop-Manual-PETROL-DIESEL-/222293665399
So your project sounds as if it is already quite far. Nice if you can do all this stuff yourself, especially with engine mounts and bellhousing.
So you are using the G52 gearbox then? Or some G5* gearbox anyway, that came with the 1RZ or with the 3L diesel?
How do you even fit the engine? From below or through the doors and cabin from above?
Then the whole part is making engine mounts? Or did you also have to lower the whole drivetrain including gearbox?
Baiscally, if you can just fit the 1JZ with "only" different engine mounts, it is pretty good, especially without moving the radiator.
I guess the 2JZ (non-turbo perhaps) would also be interesting? The turbo versions are very expensive (and powerful) but the non-turbo is maybe affordable and almost same dimensions like 1JZ?
Dione
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Fri Oct 28, 2016 1:56 am
I don't know how to start a new topic. I noticed it really is going off topic though.
Thanks for that link on ebay I think it is in russian or something so had to use translator. I e-mailed the merchant as I live in the Caribbean and they may not ship here; it contains a a lot of info though really interesting.
4wd about that manual you have can I get a copy???
Number of posts : 214
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Fri Oct 28, 2016 8:17 am
If you are having issues with shipping, those manuals are also available to purchase and download from here:
https://manuals4u.com.au/auto/toyota/toyota-hiace-1989-2004-manual/
I got an owner's manual from here recently.  I had to email the guy afterwards as I didn't get the auto email, but he responded immediately with a link.
Dione
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Fri Oct 28, 2016 2:30 pm
Thanks for that link 35. I just bought the manual.
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Thu Nov 03, 2016 9:19 pm
Hi Dione,
What I was wondering, how you remove and place the engine? From below I assume?
So you have to lift the car up quite high to roll the engine in place underneath?
And when it is underneath, use a engine hoist to lift it into place?
I mean, maybe there is a possibility if you would remove the doors, and engine hood (and second engine cover under the fixed seat) but then you would have to turn the engine?
Dione
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Thu Nov 03, 2016 9:37 pm
Hi 4wd,
No I did not go from below I just took off the engine hood hinge and all. Then I used the hoist from the passenger side and turned the engine and with the help of a few friends slowly brought it down in the engine compartment and with a lot of scraped hands and knuckles placed it in place. One if my friends who helped did the welding on the engine mounts.
The gearbox was not on the engine, the bonnet had some slight modifications because the jz is kinda higher than what would normally be in there.
All in all the modifications are not so extreme my only problem so far has been putting the electrical system in the SC back together I bought it in a very bad state. The previous owner had planned to scrap the van............... So you know what I'm dealing with:( Sad Sad Sad Sad Laughing Laughing
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Thu Nov 03, 2016 9:47 pm
Ok great to hear. Good that you are giving the van some attention, but I can imagine it could be in better shape. Also good to hear that you got it in through the doors.
Anyway, sticking with a 4 cilinder may be easier? Did the 3L get out easy the same way?
If I make a swap, it will probably be a 4 cilinder to keep it easy, reuse of existing engine mounts and gearbox.
But the V6 engines are very interesting because I think they would make a very smooth ride, and deliver enough power (190hp for example). Then I mean the 3VZ and 5VZ engines. However, they are fitting only the R150 family of gearboxes, so that means changing all that stuff. And of course, custom engine mounts.
And I don't even know if a V6 will fit.
Good luck anyway
Dione
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Thu Nov 03, 2016 10:10 pm
I got the 2L in pieces from the guy. He said it overheated and blew the head gasket only problem is that its was not the head gasket alone was damaged the block also cracked. I think he knew the block was damaged but choose not to tell me, he said he was gonna put a 4Y diesel in the van.
Yea a four cylinder would be easier but I love the sound of these straight sixes Cool cheers
I hear v sixes are more efficient engines also. The R150 family are strong gearboxes, I think the R154 is the one used in supras and they can take a lot of abuse. Not that we can do with our vans what supra guys do with their cars but its always good to know their is a little extra under our feet at times.
david
Home City : Cow Bay Nova Scotia
Registration date : 2017-01-07
PostSubject: Wiring Diagram   Sat Jan 07, 2017 9:36 pm
I just bough a 96 super custom and was hoping to get a copy of the wiring diagram if possible.
All the best,
David
Dione
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Sat Jan 07, 2017 11:51 pm
Hi david.
What engine is in your Hiace??? The file that I have with the diagrams has different sections grouped by the engine type, or you can tell me which section of the van you need diagrams for, I could maybe e-mail you the file you need.
Number of posts : 644
PostSubject: Re: Wiring Diagrams Plus for Hiace Vans   Sun Jan 08, 2017 12:19 pm
david wrote:
All the best,
David
I also have a '96 SuperCustom.
I haven't found a wiring diagram that matches the colours yet.
I did buy a multimeter from eBay with a current clamp though to help me find wires with currents in - useful for finding lighting wires etc.
The engine and chassis will be on a plate under the carpet that you can lift up when you raise the passenger seat/bonnet.
