 engine revs change with turning steeering wheel
h20 gasser
Number of posts : 14
Home City : surrey bc canada
Model and year : 1991 SC 2,4td 2wd Running with HHO assist (less emissions/better economy)
Registration date : 2012-07-28
PostSubject: engine revs change with turning steeering wheel   Tue Jul 31, 2012 12:58 am
I have from time to time found that when I enter a turn the engine seems to labour. Recently entering an offramp it appeard that the engine was about to die and the steering appeared to be without the power assist. Quick reaction hitting the gas cleared the matter but it made me wonder. Other times I can make the engine run faster or slower by turning the steering wheel (while stationary)
Hope I explained that well enough
any comments
simongd
Number of posts : 176
PostSubject: Re: engine revs change with turning steeering wheel   Wed Aug 08, 2012 10:50 pm
weird- never heard of that before. check the power steering unit, for operation. The pulley is not seized and the belt is tight and not slipping, there fluid in there. i am sure this is where you will find the problem. if the fluid is low better check for leaks. cann't think what else it could be i hope this helps.
when the power steering is working properly and you turn the wheels when the car is stationary the engine revs do drop about 50rpm or so because if the resistance of the fluid being pumped round, this is normal. so it seems there is more resistance than there should be. thats why i think the problem lies here
the shift key needs waking uP...there we go!
» is America turning into Russia ????
» medically released 3b
» How to change header text
» How to change forum name?
» How do i change ranks?
