 92 Hiace alternator not charging
Merlin_
Number of posts : 17
Home City : Nelson BC
Model and year : 92 Hiace 4x4 Diesel Cruising Cabin
99 Tercel ce *mint*
00 Tacoma *loved and now lost, sold to buy my van!*
Registration date : 2012-11-26
PostSubject: 92 Hiace alternator not charging   Mon Nov 26, 2012 9:14 am
Hello,
This is my first time posting to the board. I just bough a 92 Hiace 2.8l Diesel camper van, and in the process of driving it home 2200km the alternator seems to have quit and was running purely off the batteries.
Does this sound familiar? Could it be a fuse or connection? If I am right in assuming alternator is shot how do I get it out, pull the drivers seat?
I think I could get it rebuilt but any advice on where to source parts for RHD Japanese import in Canada would be appreciated as well. I have found a few places on line and am following up but was asked for serial numbers.
Where do I find the serial numbers on the RHD??
Thanks, any ideas would be appreciated. I sold my beloved 2000 Tacoma to buy this awesome 4x4 diesel van, however now feeling a bit fusterated by the alternator problem.
PostSubject: Re: 92 Hiace alternator not charging   Mon Nov 26, 2012 10:48 am
Alternator under drivers seat. remove seat and then the floor pan to get to it.
Most like just the diodes gone so worth getting it checked out first. Diodes are easy to obtain and are not Toyota specific.
Serial number on the alternator, or do you mean the VIN?
Have a look at Toyodiy.com for info on your vehicle.
Merlin_
99 Tercel ce *mint*
PostSubject: Re: 92 Hiace alternator not charging   Mon Nov 26, 2012 5:25 pm
Well thank you. Is the diode on the alternator or located in a cluster somewhere?
PostSubject: Re: 92 Hiace alternator not charging   Tue Nov 27, 2012 8:00 am
Yes diodes on/in the back of it.
bordurat
Home City : South Shore Mtl
Model and year : 1992 super custom limited lh107w
Registration date : 2016-09-07
PostSubject: Re: 92 Hiace alternator not charging   Thu Jul 20, 2017 7:49 pm
I know it's a long shoot but "Merlin_" What was the trouble, diodes, bad connector? I just had the same yesterday.
Number of posts : 688
PostSubject: Re: 92 Hiace alternator not charging   Thu Jul 20, 2017 8:26 pm
If you search for "alternator rectifier toyota" on ebay a whole load of replacements turn up, so it may be worth taking yours off, matching them up and buying a new one anyway.
I guess you can check with a multimeter too but you have to know the rough circuit, so it may just be cheaper to change them out.
IIRC alternators also have brush packs that can also wear and are even cheaper.
View user profile Online
Number of posts : 652
PostSubject: Re: 92 Hiace alternator not charging   Fri Jul 21, 2017 8:14 am
Yes you can take out the brushes seperately, and see if they are worn.
I usually take it out, and bring it to a company that refurbishes altnernators / starter motors etc
The bill can be low or high, depending on what needed to be fixed.
But there is stuff you can do yourself.
bordurat
PostSubject: Re: 92 Hiace alternator not charging   Mon Aug 14, 2017 8:42 pm
thank you guys. Changed the regulator and the 2 v-belts. I noticed that some people want to know how to remove the alternator step by step. I will post how to do it soon (with pictures)
PostSubject: Re: 92 Hiace alternator not charging   Mon Aug 14, 2017 10:19 pm
Brilliant!!
bordurat
PostSubject: Re: 92 Hiace alternator not charging   Thu Sep 07, 2017 7:50 pm
