 Is it possible to remove turbo?
bredzy
Number of posts : 42
Home City : Roseau
Model and year : 1997 Toyota Hiace Wagon
D-T G CABIN X
Registration date : 2010-05-29
PostSubject: Is it possible to remove turbo?    Fri Jan 18, 2013 4:49 pm
Greetings all!
Is it possible to remove the turbo in my Hiace and go straight 3.0? If so what would I need to do?
Awaiting your input! thanks!
bredzy
PostSubject: Re: Is it possible to remove turbo?    Sat Jan 19, 2013 1:55 pm
Yes but why?
You will need to source or make up an exhaust manifold to exhaust down pipe section. Any cooling route can be bridged, plug any vac pipes and that is it.
PostSubject: Re: Is it possible to remove turbo?    Sat Jan 19, 2013 4:11 pm
ECU would have to reset the pump or there would be way to much fuel being delivered. The drop in manifold pressure would make the motor un useable
PostSubject: Re: Is it possible to remove turbo?    Sat Jan 19, 2013 4:45 pm
Yes good point I'll catch up with the EFI age in a decade or two!
bredzy
Home City : Roseau
D-T G CABIN X
PostSubject: Re: Is it possible to remove turbo?    Sun Feb 03, 2013 5:22 pm
oh boy! so its not as easy as pulling a wire out? haha
tonyscott
Home City : Los Angeles
Registration date : 2013-07-17
PostSubject: Re: Is it possible to remove turbo?    Thu Jul 18, 2013 6:10 am
Yes you can do so but why you need to remove the turbo and it's not an easy task to remove you have to go to a service center but usually people not removing the turbo. i do not know why you are willing to do.
» How to Remove Ads!
» How to remove "report an abuse"SOLVED
» How to Remove or Edit the name of Header?
» How To Remove Free Forums From The Bar
» "Free Forum:" in title bar...can I remove it?
