 standard spanner set for hiace ?
belett0
Number of posts : 65
Home City : London
PostSubject: standard spanner set for hiace ?   Fri Jan 25, 2013 11:58 am
I don t have the standard tool kit in my hiace, can anyone help me on this ? From the diagram, it only says 09141 SPANNER, no idea about the size. From the toyota rav4 diagram, the spanners are :
09141‑000118X101$7.54
09141‑0003010X121$9.01
09141‑0004012X141$8.64
09141‑0005014X171$13.17
09141‑0006017X191
09141‑0008021X23 (03/1969 - 07/1969)1
09141‑0010021X23 (08/1969 - 02/1972)
mine is a hiace cruising cabin 1994 3l diesel
thanks !
David
PostSubject: Re: standard spanner set for hiace ?   Fri Jan 25, 2013 1:06 pm
Any metric spanner/socket set will do. Are you planning on doing major surgery or is it just in case?
Certainly don't buy Toyota tools but not cheap alloy ones either.
Ring open ended and sockets of the same size all come in useful.
I got a cheap socket set from Asda, selection of spanner sets and deep sockets from boot sales and expensive pliers and mole grips, not been stuck for the correct size yet.
belett0
Home City : London
PostSubject: Re: standard spanner set for hiace ?   Fri Jan 25, 2013 2:00 pm
Thanks Clive,
this is mostly just in case to complete the toolkit. I m planning to borrow all the tools for a big check up, but then I ll be on the road for 2 years, so I need to know which spanner I MUST take with me Smile
I ll probably go for a good quality spanner set, but it s a bit expensive so if I can pick only the ones I really need, this may save some money !
cheers,
David
MaXiLeeCH
Number of posts : 63
PostSubject: Re: standard spanner set for hiace ?   Sun Feb 10, 2013 2:35 am
You will need the following:
10mm
12mm
14mm
17mm
19mm
All in ring / open ended combination spanners.
You will also need a Number 1 and a number 2 Phillips head screwdriver and a plain Slot head screwdriver.
A pair of bull nose and a pair of pointy nose pliers and a pair of multi-grips would not go astray either.
The best bet is to go to one of the cheap stores and buy one of the combination spanner sets that come in a vinyl roll.
Most of the other tools I've mentioned are available in those shops too.
That is what I carry and it does the job nicely.
After all, they are just there for emergencies, not to be able to remove the engine on the side of the road.
belett0
Home City : London
PostSubject: Re: standard spanner set for hiace ?   Sun Feb 10, 2013 12:04 pm
thanks again Jeff !
that s exactly what I needed !
David
» STANDARD AND POORS RATING FOR THE U.S.
» Carter Ruck letter to Bob Parsons CEO GoDaddy.com
» Baby P Death: Ruling On 'Lenient' Jail Terms
» Scotland Yard Officers in Spain - Standard
» REHAB TRG STANDARD - LEVEL OF EDUCATIONAL PERMITTED
