 extraction of alternator
tamarack
Number of posts : 101
Home City : Vancouver
PostSubject: extraction of alternator   Fri Feb 08, 2013 11:13 am
can it come out from below or does the AC compressor need to be removed, then lifted out from the top after removal of the drivers seat and floor??? I was about to drive it away from the mechanic after not having it a year (he rebuilt the inject pump) and the battery is not charging
I asked him to check the belt first because i've had problems with it loosening before...may need a new tensioner as there is just a piece of ready rod with a bolt welded on to substitute the one that was stripped
PostSubject: Re: extraction of alternator   Fri Feb 08, 2013 11:59 am
Not sure on your engine but all others it is up only, well forward and up. Best of luck and hope it is just the diode pack.
tamarack
PostSubject: Re: extraction of alternator   Fri Feb 08, 2013 4:02 pm
yes i hope it's not the rotor. Does the AC compressor have to come out? Does it take a pro 4 hrs for the re and re?
PostSubject: Re: extraction of alternator   Mon Feb 11, 2013 8:12 am
Not ever had to touch anything but as I say not worked on your engine. 4 hours eeerm no, 1 at the most, a lot less if you've done it before.
Drivers floor out, belt loosened and moved, alt out - not complicated.
tamarack
PostSubject: Re: extraction of alternator   Wed Feb 13, 2013 11:43 pm
well the ac compressor had to be completely taken out and the bottom bolt on the alternator was almost inacessable. finally got it out. Shop put new diodes in as the old ones failed. Also put new brushes in since it was out. That was a pain and it's not going to be easy putting it iin again.
PostSubject: Re: extraction of alternator   Thu Feb 14, 2013 7:39 am
Well you live and learn.
Was the bolt inaccessable due to the AC pump being in the way or was it that you did not have the correct tool?
tamarack
PostSubject: Re: extraction of alternator   Sun Feb 17, 2013 2:43 am
toyota probably has the correct tool- it would be hard to find in a left hand drive country like here.(never seen a left hand hiace here) The third socket worked and the alternator is charging again at 13.5 Volts.
Now the starting issue has to be resolved. If I run a wire form the strater to the battery the vehicle will start but not otherwise. it might be the keyless entry/immoblizer... I think it must be a relay... do you happen to know where the starter relay (relays) are located and/or have the proper wiring diagram.
PostSubject: Re: extraction of alternator   Sun Feb 17, 2013 1:48 pm
relays are in the battery compartment or on the passenger side of the centre console hope this helps
cheers dave
PostSubject: Re: extraction of alternator   Mon Feb 18, 2013 8:25 am
Starter motor contacts most likely, the full power direct feed gets them working.
Easy to replace and available on ebay(UK). Or just fit a swtch on the direct link, press button stating?
tamarack
PostSubject: Re: extraction of alternator   Thu Feb 21, 2013 4:17 am
starting issue is intermittent. Starts sometimes 3 or 4 times then not at all. installed push button and does the same thing. I guess the best thing to do is to remove the starter and take it in to be bench tested and have the contacts replaced and the solenoid or bend-ex ([pinion gear) changed or remanufactured or rebuilt. After spending the better part of a months pay already just to get this old wagon to move occasionally, I'm starting to feel like I need something else from her if I'm going to put out any more.
tamarack
PostSubject: Re: extraction of alternator   Sat Feb 23, 2013 6:31 am
ok group,,,the old machine is back on the road again. The starter wires were not making contact as the bolts were a little loose. Should have checked this first
PostSubject: Re: extraction of alternator   Sat Feb 23, 2013 2:38 pm
On the road again!
joyfull
Number of posts : 15
Home City : Plymouth
Model and year : 1996 Hiace Vantech High Top
Registration date : 2014-03-13
PostSubject: Re: extraction of alternator   Mon Dec 21, 2015 2:13 pm
Need to replace alternator. Sounds noisy so probably bearings. Rh drive. Do you open up the drivers floor plan to access? 1996 hiace
tamarack
PostSubject: Re: extraction of alternator   Tue Dec 22, 2015 4:17 am
best to have the alternator serviced and rebuilt. A new one will cost you deep in the purse. it cost me 170 cdn dollars to have mine rebuilt (not including extraction and replacment) and it works like a charm. Check the tightness of the belt as well. Should be two belts. If you don't have the correct tools go to a shop that has worked on Hiace vans before. Ask for an estimate and after mechanic gives you an estimate ask if it will be any more that that.
joyfull
PostSubject: Re: extraction of alternator   Tue Dec 22, 2015 12:20 pm
My question was how to get it out?
PostSubject: Re: extraction of alternator   Mon Dec 28, 2015 3:33 pm
Drivers seat out and floor plate up on most Toyota engines.
Roop
Home City : Llandrindod Wells
Registration date : 2016-08-17
PostSubject: Alternator removal   Wed Aug 17, 2016 8:26 am
I have hiace super custom 1996. alternator not charging. Does anyone know if there's a manual for how to remove. Looks like air condition pump needs removing first and then the belts. I'm a bit of a novice so need some step by step guides.
bordurat
Home City : South Shore Mtl
Model and year : 1992 super custom limited lh107w
Registration date : 2016-09-07
PostSubject: Re: extraction of alternator   Thu Sep 07, 2017 7:52 pm
» I am going to have a tooth extraction
