 2lt hiace manifold vs. 2lt Hilux surf manifold
ajthompson
Home City : auckland, New Zealand
Registration date : 2013-03-09
PostSubject: 2lt hiace manifold vs. 2lt Hilux surf manifold   Sat Mar 09, 2013 1:11 am
Hi guys.
I'm starting a bit of a project on my van.
Its a 4wd hiace 1992 with hi-lo ratio and locking hubs, and it recently cracked its head :-(
so I'm taking the old smokey 3L out of it and i've now got a 5L to replace it.
heres the tricky bit... im turning the 5L into a 5L-T.
so i borrowed a surf CT20 turbo and manifold to see how it bolts up, which i does, except its sitting way too high.
the way the turbo is sitting means i cant replace the inspection panel under the drivers seat. It could still be possible, but would require some serious modification of the inspection panel and seat rails.
long story short, heres my question:
does the manifold on the hiace 2LT make the turbo sit lower, and/ or is the inspection panel of a different shape on an early supercustom to mine?
any help would be greatly appreciated!
PostSubject: Re: 2lt hiace manifold vs. 2lt Hilux surf manifold   Mon Mar 11, 2013 7:20 am
Don't know the answer, but can't you fit a short section of pipe to act as a spacer and move the turbo down?
MaXiLeeCH
Number of posts : 63
PostSubject: Re: 2lt hiace manifold vs. 2lt Hilux surf manifold   Thu Mar 21, 2013 8:21 am
You need the low- blow exhaust manifold from a turbo 2.4L Hiace. (most of the ones I have seen were pre 1989 models)
From the same vehicle you will need the oil lines and the water lines for the turbo as well.
You would probably be wise to switch to a remote oil filter setup too, as the turbo sits not too far from the stock oil filter location and it makes things more than a little warm for the oil.
(Whilst your at it, fit an oil cooler too, early model hiace's run fairly warm anyway's, fitting a turbo pushes the cooling and oiling systems to the limit.)
I hope this helps,
Jeff.
» Surf&Turf - Punbb
