 Wheel Alignment
simongd
Number of posts : 176
PostSubject: Wheel Alignment   Tue Mar 19, 2013 8:33 am
Someone on here put up he wheel alignment specs for a 1995 KZH106W 4x4.
I wonder if the same specs apply to my 1992 LH100 2 wheel drive?
Any help is appreciated. I called Toyota this week and they gave me a technical number to call on a premium rate number which I didn't find at all helpful. I don't feel I have to line Mr Toyotas pockets, but at the moment I cannot see an alternative.
These are the specs for the other bus...
_______________________________________________________________________________________
Thought I could start a list of specs. These are the factory specs as listed in my last wheel alignment data.
Van: 1995 Super Sustom 3.0TD 4WD Auto
Model: KZH106W
Factory Specified Range:
FRONT LEFT/RIGHT:
Camber -040' 050'
Caster 155' 325'
Toe -005' 005'
SAI 1145' 1315'
Included Angle 1105' 1405'
FRONT CROSS/TOTAL:
Cross Camber -030' 030'
Cross Caster -030' 030'
Cross SAI -030' 030'
Total Toe -010' 010'
REAR LEFT/RIGHT:
Camber -045' 045'
Toe -003' 003
REAR CROSS/TOTAL:
Total Toe -005' 005'
________________________________________________________________________________________
Simon
tonyscott
Home City : Los Angeles
Registration date : 2013-07-17
PostSubject: Re: Wheel Alignment   Thu Jul 18, 2013 6:00 am
I am giving you the vales if its ok then no problem otherwise you have to inspect it and adjust the wheel .
Camber
Left−right error
100 45'
Caster
Left−right error
300 1
Steering axis inclination 1300 45
Camber, caster and steering axis inclination are not adjustable.
If measurements are not within the specification, inspect the
suspension parts for damaged and worn out parts and replace
them as necessary.
Our Website
Wheel Alignment
» Category/Forum title colors and alignment help
» Footer Link Alignment Help (PunBB template)
» Category Icons => Alignment Issue
» Quick Reply and Reply alignment issues
» 7th Annual Chicagoland All Wheel Show - West
