  LH119 top upper control rod / ball joint
cjs_surf
Number of posts : 16
Registration date : 2009-05-14
PostSubject: LH119 top upper control rod / ball joint   Thu Jun 27, 2013 2:46 pm
Hi Hope you can help.
Iíve a 1991 Hiace camper itís a LH119 chassis with 4DW, it failed the DOE (Irish MOT) for too much play in the top ball joints, trouble is they are integrated into the top control arm / wishbone. I canít source any are a fair price in Dublin. Toyota quoted me 678 for the pair and the nearest †good motor factors to me is having no luck for much less. I sent a mail to BBC spares and spoken to Mark there on the phone. †
Anybody know where to get them?
If I search the Toyota part number online I get lots of factories in china selling them in bulk but no resellers.
My VIN is LH1190015861 ToyoDiy.com says itís a LH119V-RRPES, the base part numbers are 48066-29025 and 48067-29025. What are ToyoDiy like to order from?
Same part is used on any LH11x hiace.
Ciaran
PostSubject: Re: LH119 top upper control rod / ball joint   Fri Jun 28, 2013 7:34 am
Similar design on the 4WD Townace. Someone did mange to fit a replacement joint to the arm, not sure how good this was? Older Townace ones had a greasing point, some newer owners drilled one on.
Blueprint did one for the Townace.
Otherwise it is Toyota.
cjs_surf
PostSubject: Re: LH119 top upper control rod / ball joint   Fri Jun 28, 2013 11:36 am
Yes I have a greasing point but I can't see how you could change the ball joint and pass the test. Still looking found a place in Northen Ireland that may (10%) be able to get them. Tried OZ ebay as well no luck
cjs_surf
PostSubject: Re: LH119 top upper control rod / ball joint   Mon Jul 01, 2013 1:56 pm
OK so I thought I'd found them on a German Site selling nipparts but they weren't in stock,
I might be to something, I found a site http://toyota.epc-data.com/regius_ace/lh119v/76653/chassis/4802/?color&trim
and it looks like more than once toyota part will fit but I'm not 100% sure, anybody know more?
Ciaran
tamarack
Number of posts : 101
Home City : Vancouver
PostSubject: Re: LH119 top upper control rod / ball joint   Tue Jul 02, 2013 2:18 am
Have you tried Birmingham motor parts? tel 01926 485 222 website www.japanese4x4spares.co.uk
PostSubject: Re: LH119 top upper control rod / ball joint   Tue Jul 02, 2013 7:10 am
The ball joint socket was replaced/re-engineered and a new ball inserted. A lot of work for as you say dubious quality. It was done and therefore can be done.
I would bite the bullet and pay Toyota.
cjs_surf
PostSubject: Re: LH119 top upper control rod / ball joint   Mon Dec 16, 2013 9:11 pm
Got them here in the end shipped to my door for 200 http://reindeerparts.de/ They were difficult to fit, they connect to the torsion bars, the adjusters were rusted solid so I had to get new bolt and nuts from Toyota for 20 euros
PostSubject: Re: LH119 top upper control rod / ball joint   Mon Dec 16, 2013 10:37 pm
Well done!
» Scientist's Ball
» Married to an upper-class paedophile
» Saanvi Venna, 10-month-old girl abducted from her home, found deceased 10/26/12 (grandmother also murdered) - Upper Merion, PA.
» Baby P's mum at Monsters' Ball in jail
» Joint Personnel Support Unit (JPSU) is in disarray
