 how does rear air con work
mjphiace
Number of posts : 43
Model and year : 4WD LWB 2.8 Auto High Top Camper 1994
LH129V-ERPDS
Registration date : 2010-04-07
PostSubject: how does rear air con work   Thu Aug 01, 2013 7:55 pm
I have a theory about the rear air con in my campervan that we are all lucky to have as toyota owners.
Does it run off 12v only or does it need engine on to run a compressor? The reason I ask is that I have a solar panel and in this scorchio weather we are having in uk it would be nice to wire it in to keep van cool when parked up or even use it as primary air con cause can really feel drag on engine with cab air con on. I am guessing it is pretty high power ie 10 amps plus on full, but to keep it on low?
Any thoughts greatly appreciated.
PostSubject: Re: how does rear air con work   Tue Aug 06, 2013 7:36 am
As far asa I'm aware of the engine.
NZIPTV
Number of posts : 11
Home City : Taranaki, New Zealand
Model and year : 1995 Supercustom KZH100
Registration date : 2013-11-24
PostSubject: Re: how does rear air con work   Sun Dec 01, 2013 10:14 am
Although this is an old thread, I have checked the way mine is set up.
The rear air con lines run down the pillar behind the front passengers door, and connect to the same system as the front air con.
Also, the rear air con will act as a fan only if the front air con and A/C button is turned off.
I hope this helps.
PostSubject: Re: how does rear air con work   Sun Dec 01, 2013 11:25 am
Must have had a bad day on my last post.
Yes it is a secondary system branching from the front and if fitted hot/cool box. Mine had the box which could be run without the front A/C on as could the rear A/C. The rear A/C button could turn thye rear off and on from the front.
» U.K. Government rules Christians have no right to wear Crosses to work
» China gives 50 million in aid so mobile phones work on underground by the Olympics
» Work of Art: The Next Great Artist
» ATOS DECLARES DEAD PEOPLE CAN WORK
» George Osborne says welfare claimants will have to work for their dole.
