 Wing Mirrors
HiaceConvert
Number of posts : 4
Home City : Essex
Registration date : 2010-01-12
PostSubject: Wing Mirrors   Fri Aug 16, 2013 12:01 am
The mirrors on both my wing mirrors wobble at above 50 mph. Is it possible just to remove the mirrors? If so, how does one go about it?
Many thanks
PostSubject: Re: Wing Mirrors   Fri Aug 16, 2013 7:22 am
The mirror is on a plastic backing plate, this plate is pressed onto a pivot retaining ball in the housing with 3 more studs that allow the remote adjustment. Now the pivot ball and mirror plate socket are a tight fit.
I've taken several off with only one breaking the glass in the process. You have to apply pulling force all around the glass to release it other wise it cracks due to the backing plate flexing.
Is it the glass moving or the whole unit? To fix the glass moving you may need to replace the ball or socket or both. If it is the whole thing just tighten up the fixing bolts under the door cover, or the hinge on the mirror housing body.
HiaceConvert
Number of posts : 4
Home City : Essex
PostSubject: Re: Wing Mirrors   Fri Aug 16, 2013 10:48 am
Hi Clive
Many thanks for your reply. It is the glass that is moving. Any "special tool" or "technique" use to ensure even force around the glass?
Wing Mirrors
» I see the left-wing bedwetters are OUTRAGED by some idiot they never heard of before today...
» Check out this ranting, left-wing lunatic....
» What the hell is wrong with these left-wing idiots?
» American Left-Wing Nationalism
» Right-wing politics, left-wing aesthetic
