 Couple of major Questions Please help!
Dinka
Number of posts : 10
Home City : Colombo
Registration date : 2013-08-22
PostSubject: Couple of major Questions Please help!   Thu Aug 22, 2013 6:19 pm
Hey there folks ! My dad's good old Hiace LH103 1994 DX has been with us for 14 years and still goes like sting but last decade or so he didn't really have time to maintain it and its been going down hill but still works like a charm.. So I have been driving it for the past 2 weeks and fall in love with it all over ! And to say I love to drive it over our Toyota Rav4 2003 lol.. Anyways I'm gonna give it a make over so before I start I have to ask you good people some questions regarding it.
1.Can some one tell me what this engine is for example like (2JZ,1fz)
It says its a 3L 2779 cc engine ? Is this a Turbo Engine ? (This is not a picture I took but got it from the internet its the same thing.
2.Does this have ABS braking ? Because I just replaced the fuse that was sort of corroded in the battery compartment that said ABS 60A ? But I can't find the ABS unit anywhere to be seen ? Where is it located ?
3.Where is the Air Filter ?
4.sort of a odd issue.. Whenever the Head lamps/Signal lights/break lights or the switch the Blower to the high flow range the Oil level low warning indicator on the cluster lights up for no apparent reason because the oil level is at the dot perfect this only happens when the following things are switched on other than that there is no issue and when ever the headlamps are turned on I can not turn on the Radio it will not power up ? Its like when I turn the Head lamps on a Huge power drop occurs. and when ever the turn lights are on the speedo flickers
Got more stuff to ask but I will stop from here ask them later on as I start putting it back together.
Thanks mates:D
PostSubject: Re: Couple of major Questions Please help!   Fri Aug 23, 2013 5:27 am
Air filter is behind the drivers side front wheel on RHS vehicles. Get at it from underneath. As for the ABS we have the same fuse but don't know whether it is actually there Smile Have fun
Dinka
Home City : Colombo
PostSubject: Re: Couple of major Questions Please help!   Fri Aug 23, 2013 5:48 am
AussieQ wrote:
Air filter is behind the drivers side front wheel on RHS vehicles. Get at it from underneath. As for the ABS we have the same fuse but don't know whether it is actually there :)Have fun
Thanks for answering some of the questions Smile Yeah ABS is no where to be found
BFG
Number of posts : 24
Home City : West Midlands, UK
Model and year : 1994 HiAce Reimo conversion, 2.8 auto.
Registration date : 2012-06-21
PostSubject: Re: Couple of major Questions Please help!   Tue Aug 27, 2013 4:06 pm
That's a 3L engine, 2.8 litre normally aspirated (non-turbo). Same as we've got in ours!
Electrical issues are always fun. Try pulling all the fuses and cleaning the contacts, and also check the alternator and engine earthing points. Also look for any damage to wiring where it's bundled together and going through a bulkhead. Somewhere on the forum there's a wiring diagram - it might help you.
Rob
» A couple of general questions
» Authorities Investigate Strange Slaying of Young Ohio Couple
» Major David Vivian Currie, The Canadian Armoured Corps Only WW-2 VC
» Belgian couple spot the men who stole their car in Belgium on a Spanish beach
» The McCanns Are A Nasty Couple. But A Reflection Of Our Times
