 A few problems with my Super Custom Please Help.
am-i-bothered
Home City : NZ
Registration date : 2013-11-13
PostSubject: A few problems with my Super Custom Please Help.   Wed Nov 13, 2013 9:08 am
Hi guys, if you have any suggestions please sing out here are the following problems:
1994 Automatic 1kzte Super custom
- Rev Counter not working (was intermittent)
- Fuel Gauge always showing full goes down a slightly as it gets really low. (could be build up on the rheostat in tank?)
- Automatic brake solenoid not disengaging when putting my foot on the brake to put into reverse from park.
PostSubject: Re: A few problems with my Super Custom Please Help.   Fri Nov 15, 2013 9:54 am
Loose connection on speedo. As long as the gearbox is changing ok the sensor is sending the correct signal to the ECU, so it would be from there.
Fuel float arm needs bending? I don't think there is an inspection point through the floor so i'd guess the tank needs to be dropped to get access?
Change auto fluid.
» Bank of England warns of problems
» Moltke's tactical problems
» Has 'the Right to Buy' and lack of rent controls caused most of the UK's housing problems?
» Forum causing problems to access to webmail personalized
