 small noise like drum brakes, but from the engine bay
belett0
Number of posts : 65
Home City : London
PostSubject: small noise like drum brakes, but from the engine bay   Fri Nov 29, 2013 5:17 pm
Hi guys,
I'm having a new noise since 2 days on my hiace cruising cabin 94, and starting to worry about it as I will enter Guatemala in a few days...
Noise sounds like drum brakes in action, or bad pads sliding on the disc, could be a bearing, but not sure yet, and it definitely comes from the engine bay. When parked, It's there as soon as I start the engine, and increases in sync with engine revs (a bit louder and higher pitch). I was looking at the alternator, seems very hot even after a short 3 min drive, is that ok ? We had to replace the alternator before the trip, and the one is a reconditioned one. No warning light yet, but I don't have the tools to check the voltages.
It seems to get worse every day, so I need some advice before going any further. I'm in Belize now and it's going to be tricky to find a good mechanic in a safe place.
Thank you,
David
PostSubject: Re: small noise like drum brakes, but from the engine bay   Sat Nov 30, 2013 8:28 am
With the engine cold, jam or hold the fan still and start the engine. Use a length of hose and place one end on the alt the other to your ear, if it is not that move around the engine, BEWARE just because the fan is not moving the belts will be. If you have still not found the source release the fan it may be that.
belett0
Home City : London
PostSubject: Re: small noise like drum brakes, but from the engine bay   Sun Dec 01, 2013 4:02 pm
Hi Clive,
thanks for the tip about the hose ! We have a spare meter in the trunk ready for that Smile
David
MaXiLeeCH
Number of posts : 63
PostSubject: Re: small noise like drum brakes, but from the engine bay   Tue May 20, 2014 12:53 am
If your van is air conditioned, check the idler pulley for the A/C belt.
It is low mounted under the alternator and it's bearings fail after a time.
There is also the other idler pully on the top of the A/C belt but it does not contact the belt all the time (It's there to stop the belt from whipping back and forth under load) and as such it does not make a continuous noise when its bearings go.
I hope this helps.
MaXiLeeCH
PostSubject: Re: small noise like drum brakes, but from the engine bay   Tue May 20, 2014 12:55 am
Just had another thought, maybe it is the water pump bearings?
How old is the pump?
That would be worthwhile to check too.
belett0
Home City : London
PostSubject: Re: small noise like drum brakes, but from the engine bay   Sat May 24, 2014 11:08 pm
Hi Jeff !
thanks for the update, noise was coming from the idler pulley for the AC. Our AC is shot anyway, so not a big loss (we have a big missing pipe below the van )
thanks again !
David
» 1972 Small Pack
» small enterprise
» WWI Small Box Respirator
» How to Make a "Small Avatar" in Posting Homepage Menu? (phpBB)
» This forum brakes your rules: Illicit contents, Hateful or abusive content, Defamatory content and / or affecting ...
